1 Reply Latest reply on Nov 26, 2014 7:36 AM by Mylenium
    Camera / 3D layer confusion
    Vauneen34
      Hi, I've been having a problem with how the camera has been moving objects when used together with a null object. I use the normal method - parenting a camera to the null object, using separate XYZ position (the text layers I'm manipulating are 3D) The problem is, is that it doesn't look like I'm using the camera tool at all - It looks as if I am just using normal position keyframes. I am trying to make it appear as if the camera is tracking past the letters, not the letters past the main view (if that makes sense.)
      The second problem is that certain png files that I import become invisible when I enable 3D - Why is this? Using AE CC 2014.
      Thanks in advance. Appreciate the help.
