2 Replies Latest reply on Nov 27, 2014 5:50 PM by Xoco
    Problem with jQuery html() Method
    Xoco Level 3
      I try to use jQuery html() Method for to show letter to letter a string.
      for( i = 0; i < conEmpresa.length; i++){
           text += conEmpresa.substring(i, i+1);
           sym.$("conEmpresa").html(text);
      But always show all complete string. I try too:
           setTimeout( function(){ sym.$("conEmpresa").html(text); }, 100);
      But nothing, any ideas? Thanks.
        • 1. Re: Problem with jQuery html() Method
          joel_pau Level 5
          So,
          One solution:
          sym.$("Text").html("");
          var increment = 0;
          var str = "A typewriter effect. You can change this text.";
          var timer = setInterval(function() {
          sym.$("Text").html(str.substring(0, increment++));
          if (increment >= str.length) clearInterval(timer);
          }, 100);
          Another solution:
          var text = "A typewriter effect. You can change this text.";
          $.each(text.split(""), function(index, item){
          setTimeout(function(){ sym.$("Text").html(sym.$("Text").html() + item) }, 100*index);
          Findings: You've got 2 solutions: with or without jQuery file. It means also before and after Edge 5.0
          • 2. Re: Problem with jQuery html() Method
            Xoco Level 3
            Both solutions work fine, but only with first solution the HTML br tag are displayed correctly.
            Thanks for all.
