3 Replies Latest reply on Mar 1, 2015 8:13 PM by yjling
    Batch renaming suffix and relinking in InDesign
    Sachinji Level 1
      It is possible to documents links can be renamed with updated link as suffix "_1 or _2 or _3..........: only do with the new simple script.
      There are many scripts I have found that rename and relink with prefix. I do not find any script that renames and relink with suffix.
      Suppose a file name is "art.ai" if we use prefix scripts it changes like "1_art.ai" in this case both are not in sequence in list preview of 100 links.
      I desperately needed something automatic.
      Sachin
        • 1. Re: Batch renaming suffix and relinking in InDesign
          If you want numbered files to display sequentially by Name in the Finder, the prefix needs to have a leading 0 for numbers less than 10, so instead of 1, 2, 3... 10  you need 01, 02, 03...10, 11.
          The script could check for numbers less than 10 and add a leading 0 to the prefix. In AppleScript it would be something like this. If mycounter is 6 you get 06-myfilename, if it's 16 you get 16-myfilename:
          --a counter in a repeat loop
          set mycounter to 6
          --the number prefix to be added to the file name
          set myprefix to mycounter as string
          --check if the number is less than 10 and add a leading 0
          if (count of characters in myprefix) is less than 2 then
              set myprefix to "0" & myprefix
          end if
          --returns 06-myfilename
          display dialog myprefix & "-myfilename"
          • 2. Re: Batch renaming suffix and relinking in InDesign
            Sachinji Level 1
            Thanks, Rob Day.
            There are many scripts available for prefix.
            I need to add suffix
            Example There are 2 or 3 folders with link.
            When package using book or manually second folders all the link moving in first folder message coming for replace,
            I skip those file, it may be 1, 30, 40 images.
            Again open 2nd document indd and want to rename the linked images with base name + suffix (_1) and relinked,
            Than move all these renamed files in the first folder and repeat in third folder with base name + suffix (_2) and relinked.
            When all the links are in the same folder first repeating images are looking together with there basename + suffix.
            As shown in the screen grab in the post.
            • 3. Re: Batch renaming suffix and relinking in InDesign
              yjling
              Hi Sachinji, I am very interested in the scripts that allows one to add prefix to the links. Do you know of any?
              Thanks!
