2 Replies Latest reply on Dec 1, 2014 7:49 AM by cmworster
    Is it possible to leverage InDesign Server templates in a custom web app?
    cmworster
      Hi there,
      I am building a custom web app and was hoping to leverage our existing InDesign Server templates within our web app. What I would like to do, is based on user input, show my template with the user's input in the browser. I have looked through the API guides for InDesign Server CS6, but I haven't been able to conclusively find anything that will allow me to use the APIs to call the server, send the data points the template requires, and then get an image back from the server.
      I believe this is possible, I am just not sure how to achieve it! Any ideas or articles that help push me in the right direction would be extremely helpful!
      Thank you!
      Marshall
        • 1. Re: Is it possible to leverage InDesign Server templates in a custom web app?
          Max Dunn Level 1
          Yes it's completely possible. There are two parts to making something like this work:
          1. The scripts themselves. You can generally script InDesign Server and desktop InDesign exactly the way using ExtendScript. So that's the part of the process where your script receives variables and passes them into the template and replaces something you've identified as variable, whether text or an image or something else (perhaps a color theme, etc.). You should get your scripts running on desktop before playing around with server.
          2. The messaging between your web app and the server. Whatever language you are using (i.e. PHP, .Net, Java, Ruby…) there is a way to make a SOAP call to InDesign Server to tell it basically "run this script with these parameters". You should get the "hello world" script running from a SOAP call on the server before using your real variable-driven document.
          The documentation of these things is available here:
          http://www.adobe.com/devnet/indesign/sdk.html
          You need to download the InDesign Server SDK (don't worry if you're on CC and it says CS6, almost nothing changed) and the InDesign Scripting SDK. The Server SDK deals with part #2 above, the Scripting SDK with part #1.
          It really isn't that hard. I should warn you, though, that it is addictive and once you do your first one you will become all-powerful and want to do nothing else. :-)
          Good luck and don't hesitate to ask questions.
          Max
          http://blog.siliconpublishing.com
          • 2. Re: Is it possible to leverage InDesign Server templates in a custom web app?
            cmworster Level 1
            Thank you Max! This is great information and I will definitely see if I can get this up and running!
            Much appreciation,
            Marshall
