• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ColdFusion 11 installer stalling on OS X 10.10.1
New Here ,
Nov 27, 2014 Nov 27, 2014
I'm trying to install ColdFusion 11 on a fresh install of OS X 10.10.1 with Apache. The installer gets to 100% with the message
Installing... Install Merge Module(Build Time): CFSolr_osx....
It then just sits there doing nothing. Looking at Force Quit I see the following
With the ColdFusion Installer showing the error at the top and the 2 java windows the installer opened called LAX.
I can see the installation log in the ColdFusion 11 directory and the last entry is this
Install Merge Module:     Z:\installers\CFSolr\installers\mergemodule\/CFSolr_osx.iam.zip
                          Status: SUCCESSFUL
                          Additional Notes: NOTE - Installing: SubInstaller1.zip
Not that I chose not to install the Solr components in the installer.
Any suggestions would be great as it's driving me mad.
Views
817
Translate
Translate
Report
Report
Community guidelines
community guidelines
Are you getting any error in ColdFusion11 installation log file?
Votes
Translate
Translate
Report
Report
New Here ,
No, everything in the log succeeds and the entry above is the last entry.
Votes
Translate
Translate
Report
Report
Nov 28, 2014 Nov 28, 2014
Can you restart you machine and crosscheck your cfm requests working fine or not?
Kindly let me know following:-
  1. Have you configured any web server there?
  2. If so, which external web server have you configured there?
  3. Web server major & minor version detail?
Votes
Translate
Translate
Report
Report
New Here ,
Restarting has no effect. When accessing cfm requests I just see the code.
I'm running OS X Server V4 with websites turned on.
Server version: Apache/2.4.9 (Unix)
Server built:  Sep  9 2014 14:48:20
and the rest of the spec from the log excluding the custom actions which were all successful
java.class.path:
    /Volumes/ColdFusion Installer/ColdFusion Installer.app/Contents/Resources/Java/Execute.zip
    /Volumes/ColdFusion Installer/ColdFusion Installer.app/Contents/Resources/Java/IAClasses.zip
    /Volumes/ColdFusion Installer/ColdFusion Installer.app/Contents/Resources/Java/installscript.zip
    /Volumes/ColdFusion Installer/ColdFusion Installer.app/Contents/Resources/Java/linking.zip
ZGUtil.CLASS_PATH:
sun.boot.class.path:
    /private/tmp/IA537269603/jre/Contents/Home/jre/lib/resources.jar
    /private/tmp/IA537269603/jre/Contents/Home/jre/lib/rt.jar
    /private/tmp/IA537269603/jre/Contents/Home/jre/lib/sunrsasign.jar
    /private/tmp/IA537269603/jre/Contents/Home/jre/lib/jsse.jar
    /private/tmp/IA537269603/jre/Contents/Home/jre/lib/jce.jar
    /private/tmp/IA537269603/jre/Contents/Home/jre/lib/charsets.jar
    /private/tmp/IA537269603/jre/Contents/Home/jre/lib/jfr.jar
    /private/tmp/IA537269603/jre/Contents/Home/jre/classes
java.ext.dirs:
    /Users/linfoots/Library/Java/Extensions
    /private/tmp/IA537269603/jre/Contents/Home/jre/lib/ext
    /Network/Library/Java/Extensions
    /System/Library/Java/Extensions
    /usr/lib/java
java.version                  == 1.7.0_55 (Java 1)
mrj.version                  == 3.1
java.vm.name                  == Java HotSpot(TM) 64-Bit Server VM
java.vm.vendor                == Oracle Corporation
java.vm.version              == 24.55-b03
java.vm.specification.name    == Java Virtual Machine Specification
java.vm.specification.vendor  == Oracle Corporation
java.vm.specification.version == 1.7
java.specification.name      == Java Platform API Specification
java.specification.vendor    == Oracle Corporation
java.specification.version    == 1.7
java.vendor                  == Oracle Corporation
java.vendor.url              == http://java.oracle.com/
java.class.version            == 51.0
java.library.path            == /Volumes/ColdFusion Installer/ColdFusion Installer.app/Contents/Resources/Java
java.compiler                == null
java.home                    == /private/tmp/IA537269603/jre/Contents/Home/jre
java.io.tmpdir                == /var/folders/bz/vcxzrqdn0r77x45c6l0p7kw40000gn/T/
os.name                      == Mac OS X
os.arch                      == x86_64
os.version                    == 10.10.1
path.separator                == :
file.separator                == /
file.encoding                == UTF-8
user.name                    == Linfoots
user.home                    == /Users/linfoots
user.dir                      == /Volumes/ColdFusion Installer
user.language                == en
user.region                  == null
__________________________________________________________________________
Installed Feature(s) ColdFusion of Adobe ColdFusion 11
Install Begin: NOVEMBER 27, 2014 10:59:25 AM GMT
Install End: NOVEMBER 27, 2014 11:43:46 AM GMT
Installed by InstallAnywhere 15.0 Premier Build 4538
User Interactions
#Remote Component Administrator Credentials
JETTY_USERNAME=admin
JETTY_PASSWORD=*******
JETTY_PASSWORD_CONFIRM=*******
#Earlier Versions of Adobe ColdFusion installed?
CF_INSTALLED_PROMPT=0
CF_INSTALLED_PROMPT_1=
CF_INSTALLED_PROMPT_2=No
CF_INSTALLED_PROMPT_BOOLEAN_1=0
CF_INSTALLED_PROMPT_BOOLEAN_2=0
#Server Updates
AUTO_ENABLE_UPDATES_UI=1
#Install
-fileOverwrite_/tmp/796312.tmp/node.tar=Yes
-fileOverwrite_/tmp/796312.tmp/weinre.tar=Yes
Votes
Translate
Translate
Report
Report
Participant ,
Jan 06, 2016 Jan 06, 2016
LATEST
Right click on latest java window and quit that window.
The installation will continue and should complete successfully.
After installation, you will configure ColdFusion to start on System boot e.g.
  • computerName:~ user$ cd /Applications/ColdFusion11/cfusion/bin/
  • computerName:bin user$ sudo ./coldfusion start
Then start the server
  • computerName:bin user$ ./coldfusion start
Votes
Translate
Translate
Report
Report
Resources
Documentation
