18 Replies Latest reply on Mar 21, 2007 9:17 AM by Newsgroup_User
    Stage position
    Level 7
      Hello:
      I would to put the stage in loc(0,0) when I press Ctrl+Alt+1 to view in
      authoring mode my movie. But always the stage is in other position.
      Do you know how to position the stage in 0,0 location? I have tried in Movie
      properties but I don't find any parameter for this. I remember in newer
      versions this possibility.
      Thank you very much
        • 1. Re: Stage position
          Level 7
          I believe setting (the stage).rect will do it.
          Craig Wollman
          Lingo Specialist
          Word of Mouth Productions
          212-928-9581
          www.wordofmouthpros.com
          "Anne" <anmalo42@lycos.es> wrote in message
          news:etlusj$3h$1@forums.macromedia.com...
          > Hello:
          > Movie properties but I don't find any parameter for this. I remember in
          > newer versions this possibility.
          > Thank you very much
          • 2. Re: Stage position
            Level 7
            Thank you.
            No, it does not.
            "forum.macromedia.com" <lingoboy@wordofmo.com> escribió en el mensaje
            news:etlv11$82$1@forums.macromedia.com...
            > Craig Wollman
            > Lingo Specialist
            > 212-928-9581
            >> Hello:
            >> Thank you very much
            • 3. Re: Stage position
              Level 7
              I must be missunderstanding your issue. I use that all of the time to move
              the stage.
              Craig Wollman
              Lingo Specialist
              212-928-9581
              news:etm2tu$4v0$1@forums.macromedia.com...
              > Thank you.
              > No, it does not.
              >> Craig Wollman
              >> Lingo Specialist
              >> 212-928-9581
              >>> Hello:
              >>> Thank you very much
              • 4. Re: Stage position
                Level 7
                I think actually you're not talking about using Lingo to do this but using a
                built in feature of Director for authoring. If that's so, you might want to
                try the basic forum instead of the Lingo forum. If it is a Lingo solution
                you're looking for could you give a bit more detail? Do you want to move
                the stage to 0,0 so that you maximize authoring window space on the monitor?
                Craig Wollman
                Lingo Specialist
                212-928-9581
                > Thank you.
                > No, it does not.
                >> Craig Wollman
                >> Lingo Specialist
                >> 212-928-9581
                >>> Hello:
                >>> Thank you very much
                • 5. Re: Stage position
                  Level 7
                  Thank you very much.
                  I don't know If this can do it with Lingo or not.
                  When I press Ctrl+Alt+1 (in authoring mode) I only see the stage (score,
                  cast, etc. are not visible) but the stage is cutted I can't see the stage
                  completly. How can I see the whole stage?
                  thanks.
                  • 6. Re: Stage position
                    Level 7
                    Where is the stage cut off? At the top or to the left? If so, you need to
                    change the stage location in the property inspector. Go to CNT-Alt-s then
                    click on the movie tab. If you don't see it, click on the stage and it will
                    show up.
                    There you can change the left and top coordinates. I hope this helps. I'm
                    still not sure it's what you want.
                    Craig Wollman
                    Lingo Specialist
                    212-928-9581
                    news:etn0la$dvr$1@forums.macromedia.com...
                    > thanks.
                    • 7. Re: Stage position
                      James Newton, ACP Level 3
                      For a Lingo solution, you could try executing the following lines in the Message window:
                      vRect = the stage.rect
                      vRect = vRect.offset(-vRect.left, -vRect.top)
                      (the stage).rect = vRect
                      This will place the top left corner of the stage at the top left corner of your monitor. If your stage is bigger than the monitor, then you could try:
                      1) Opening the General Preferences pane (Director | Preferences | General... on Mac Edit | Preferences | General... on Windows)
                      2) Ensure that the Show Stage Scrollbars checkbox is selected
                      3) Resize the Stage so that it fills the monitor (Green title bar button on Mac, drag an edge or a corner on Windows)
                      4) Select 50% in the Scale contextual menu at the bottom left of the Stage window
                      Other solutions include double-clicking on the hand or magnifying glass icons in the Tool palette.
                      • 8. Re: Stage position
                        Level 7
                        Thank you very much:
                        This does not work.
                        What mean: "Go to CNT-Alt-s" ?
                        I only want to show my movie in full screen in authoring mode. The top of
                        the image is cutted.
                        In the stage properties movie I have this: rect(3, 126, 1027, 894)
                        But when I try to change any parameters it come back again to rect(3, 126,
                        1027, 894).
                        In Display Template Tab I have tried to modify location to 0,0 but the top
                        continue cutted.
                        Can you help me, please
                        thanks again
                        • 9. Re: Stage position
                          Level 7
                          CNT-alt-s brings up the property inspector
                          Craig Wollman
                          Lingo Specialist
                          212-928-9581
                          news:etoiqs$fqj$1@forums.macromedia.com...
                          > This does not work.
                          > 1027, 894).
                          > continue cutted.
                          > thanks again
                          • 10. Re: Stage position
                            Level 7
                            Thank you:
                            Whaty ou told me does not work.
                            I see a grey frame on the top (about 50 pixels).
                            My screen resolution in Windows XP is 1024x768. I make a movie with the same
                            resolution and in author mode when I press CTRL-ALT-1 I must see the full
                            screen but I get a grey frame on top. And I don't see my movie totally.
                            Do you know how to fix this?
                            Thanks again and again.
                            • 11. Re: Stage position
                              Level 7
                              I think that this grey frame is the title bar for the stage window. You
                              can turn that off in the Display Template tab of the Property Inspector
                              window. In the bottom half of this window there are four check boxes.
                              Turn off the one titled, "Visible".
                              That may solve your problem.
                              Rob
                              _______
                              Rob Dillon
                              Adobe Community Expert
                              http://www.ddg-designs.com
                              412-243-9119
                              http://www.macromedia.com/software/trial/
                              • 12. Re: Stage position
                                Level 7
                                Thank you:
                                The Visible=false and the problem continue.
                                • 13. Re: Stage position
                                  Level 7
                                  If you open the Display Template tab of the Property Inspector window
                                  and type in something in the Title space and then use Fullscreen View,
                                  do you see what you typed in the grey space? If this is so then you are
                                  seeing the titlebar for the stage window.
                                  What type of window are you using?
                                  Rob
                                  _______
                                  Rob Dillon
                                  412-243-9119
                                  • 14. Re: Stage position
                                    Level 7
                                    Thank you:
                                    When I type something in Title space I don't see anything because Director
                                    is in authoring mode. If I make a projector I see the title and full screen
                                    is right, but in author mode I don't see title and I get grey space on top.
                                    > What type of window are you using? Document.
                                    • 15. Re: Stage position
                                      What size is your monitor? What result do you get when your type the following in the Message window?
                                      put the desktopRectList
                                      • 16. Re: Stage position
                                        Level 7
                                        > What size is your monitor? 1024 x 768
                                        > put the desktopRectList [rect(0, 0, 1024, 768)]
                                        Thank you very much
                                        • 17. Re: Stage position
                                          Level 7
                                          Well that's the answer. I dont' think you can see the whole stage when the
                                          stage is the same size of the monitor because of the title bar. I know if
                                          was mentioned that you can get rid of the title bar but I thought that was
                                          only for a projector.
                                          But yes there was a way to view the whole stage and have it look like a full
                                          screen projector. I thought it was CNT-ALT-SHFT-<something> but I've tried
                                          a few things and I haven't been able to make it work. but of course that is
                                          only for running a movie, not when it's stopped and you're coding or
                                          developing
                                          Craig Wollman
                                          Lingo Specialist
                                          212-928-9581
                                          news:etra70$3uu$1@forums.macromedia.com...
                                          > Thank you very much
                                          • 18. Re: Stage position
                                            Level 7
                                            Thank you very much to all of you.
