0 Replies Latest reply on Mar 19, 2007 1:58 PM by EliteScientist
    Potential Bugs In the ViewStack Container
    EliteScientist
      Bug 1:
      when moving the children around by calling setChildIndex, it causes the container to loose the selectedIndex reference. This causes the selectedChild to stay on top of any of the children before it until it is set at the selectedChild again.
      this method should be overriden and the _selectedIndex should be changed accordingly.
      Bug 2:
      Line 1264 & 1265 are reveresed causing an error when any child is moved previous to calling removeAllChildren.
      1264: selectedIndex = -1;
      1265: _selectedIndex = -1;
      these lines are executed when the last child has been removed.
      when the setter for selectedIndex is called it dispatches a value commit event, which causes any ChangeWatcher's that are binded to selectedChild to execute.
      these execute before line 1265 is executed causing an (index is out of bound) exception to be thrown when the ChangeWatcher tries to get the value for selectedChild.
      the container should set _selectedIndex to -1 first, so any bindings to selectedChild won't cause an exception.
