2 Replies Latest reply on Nov 28, 2014 8:22 AM by A.T. Romano
    DVDへの書き込みでレコーダーが検出できない
    まりたく
      DELLのノートパソコンでプレミアエレメンツ12が購入時に入っていてダウンロードしたPCです。10月に購入しました。
      書き出し、デスク、DVDと進むと レコーダーの場所に何も表示されず、
      ステーサス:レコーダーが検出できません と表示され、DVDに書き込めません。
      AVCHDにするとレコーダーが検出されて書き込みができます。
      AVCHDでレコーダーの場所で表示されるのが D MATSHITA DVD+-RWUJ8E2 です。
      DVDで書き込みたいのですが対処法を教えてください。
      ムービーメーカーやビデオパッドでの書き込みはできます。
      よろしくお願いします。
        • 1. Re: DVDへの書き込みでレコーダーが検出できない
          Web translation
          Is a DELL laptop in the premiere elements, 12 when you buy and download PC. Purchased in October.
          Export and proceed with desks, DVD recorder where nothing not appear,
          Stasis: cannot detect the recorder and the DVD cannot be written.
          AVCHD and recorder is detected and can be written.
          D MATSHITA DVD+-RWUJ8E2 is displayed in the location of the recorders in AVCHD.
          Please tell me solution is you want to burn on DVD.
          You can write in Movie Maker and video pad.
          Thank you in advance.
          Set your Premiere Elements DVD output to a folder on your hard drive and then use the FREE Imgburn to burn the folder to disc for DVD
          Read http://forums.adobe.com/thread/1322583 for notes on installing Imgburn WITHOUT any toolbar add-ons... Set Imgburn to use the slowest burn speed your drive and media will use... I set my burn speed to 1x and let Imgburn adjust to the actual minimum
          • 2. Re: DVDへの書き込みでレコーダーが検出できない
            A.T. Romano Level 7
            For Premiere Elements 12/12.1 Windows...
            1. Uninstall using usual Control Panel way.
            2. Do a free ccleaner run through to get rid of leftovers from incomplete installs uninstalls.
            https://www.piriform.com/CCLEANER
            3. Reinstall with antivirus and firewall(s) disabled.
            If the above does not solve the problem and if you have a only a DVD CD burner, then consider
            http://helpx.adobe.com/creative-suite/kb/cd-dvd-drive-recognized-application.html
            What burn software do you have on your computer?
            Please let us know if any of the above worked for you.
            Thank you.
            ATR
            Add On....I just saw John's reply after I had posted mine. His is a workaround to obtain a DVD-VIDEO on DVD with ImgBurn in conjunction with Premiere Elements burn to folder. It is not a solution for burning to disc just using Premiere Elements.
