0 Replies Latest reply on Nov 28, 2014 10:35 AM by geohei_2
    DVB-S ts stream missing audio / smart rendering
    geohei_2
      Hi.
      I have a DVB-S recorded HD stream and would like to process (cut, effects, title, ...) it using Premiere Pro CS6.
      Size 8.481 GB
      Duration 02:09:59.05
      Mux type TS Stream
      TS mux rate 6.675 Mbps
      Video:
      Encoding H.264 VideoStreamID x2FF
      Frame rate 25.00 fps Encoding size 1920 x 1080
      Aspect ratio 16:9 Header bit rate 20.000 Mbps
      VBV buffer 380 KBytes Profile High/4.0
      Progressive Interlaced Chroma 4:2:0
      Entropy mode CABAC Bit rate 7.614 Mbps
      Audio Stream: 1 (Primary)
      Codec AC3 Format AC3 stream
      Channels 5.1 Language deu
      PID x303 PES Stream Id xBD
      Bit rate 384 Kbps Sampling rate 48000
      Sample size 16 bits
      Audio Stream: 2
      Channels 2.0 Language eng
      PID x304 PES Stream Id xBD
      Sample size 16 bits
      Subtitle: 1-1
      Type DVB Teletext PID 0x20
      Language deu Page 100
      1. I noticed that audio is not recognized. Is this normal? Can I do/install something to permit Premiere Pro to see embedded audio?
      2. Is it possible to use smart rendering with Premiere Pro?
