0 Replies Latest reply on Nov 28, 2014 12:52 PM by Sandies
    Trigger an animation only once in Adobe Edge
    Sandies
      I am using this code http://www.timjaramillo.com/code/edge/_source/gyroscope.zip to start an animation on the Edge timeline when tilting the phone to the right. But I need this animation to play only once and play another animation in loop after. Right now the animation starts again each time I tilt the phone to the right, whitch is normal because the script is triggered window.ondevicemotion.. Is there a way to stop this script of happening after it runs once? Here is the complete script that I have in the "CompositionReady" code tab. As you can see I start the animation sym.play() when the status is = 1
      //Detect if the browser supports DeviceMotionEvent
      if (window.DeviceMotionEvent != undefined) {
        //ondevicemotion is fired when iOS device detects motion
        window.ondevicemotion = function(e) {
        //ax is the movement on the x axis.
        //This motion is used to move the ship in the game
        ax = event.accelerationIncludingGravity.x * 5;
        ay = event.accelerationIncludingGravity.y * 5;
        //Status 0 is start, 1 is left, 2 is right, 3 is stay
        if(status == 0){ //initial condition
        status = 3; //stay
        sym.$("txt_test").html("Status: level");
        if(ax > 14 && status != 2){ //move right on device
        status = 2;
        sym.$("txt_test").html("Status: move right");
        if(ax < -14 && status != 1){ //move left on device
        status = 1;
        sym.$("txt_test").html("Status: move left");
        sym.play();
        if(ax > -14 && ax < 14 && status != 3){ //device held steady
        status = 3;
        sym.$("txt_test").html("Status 0");
