8 Replies Latest reply on Apr 25, 2007 3:16 PM by DannyDubroc
    Facing problem when requesting mxml
    mayabazar
      Hi ,
      When I try to run mxml I am getting following error in my browser.
      Compilation Results
      Errors, warnings or exceptions were found while compiling null.Visit the online Flex documentation or API reference for further information.
      An error occured on the server. Server error is: 'Error occurred in server thread; nested exception is: java.lang.NoClassDefFoundError: flex2/compiler/util/CompilerControl'
      I have done following steps to setup Flex module for Apache and IIS
      1) Installed Apache2.2
      2) Downloaded full version of Flex module for Apache and IIS and installed
      3) While installation I have pointed Apachi Home folder
      4) Rebooted the System (my OS is Win Xp Sp2)
      5) In the installation itself it has copied some sample projects , to apache /Apache Software Foundation\Apache2.2\htdocs\ folder
      when I try to mxml (any ) it is giving above error.
      Please suggest me what was wrong here
      Thanks in advance
      Venu
        • 1. Re: Facing problem when requesting mxml
          catalinanastasoaie Level 1
          Could you please open a command prompt and type "set" and then hit enter and then copy all the result and paste it here in a new post?
          Could you tell us what version of flex sdk do you use? If you are using flex sdk 2.0 please update it to flex sdk 2.0.1
          Regards,
          Catalin
          • 2. Re: Facing problem when requesting mxml
            mayabazar Level 1
            Hi Catalin,
            Thanks for reply. I have downloaded full version of flexmodule, so it has flex compiler too. I already have bin folder of flex in the system path. Please find my system path is as follows and please let me know if anything wrong
            OS=Windows_NT
            Path=C:\CFusionMX7\verity\k2\_nti40\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOW
            S\System32\Wbem;C:\Program Files\Common Files\Adobe\AGL;C:\Work\Java\bin;C:\Work
            \Ant\bin;C:\Program Files\TortoiseCVS;C:\Program Files\Adobe\Flex Builder 2\Flex
            SDK 2\bin;C:\Program Files\Adobe\Flex Builder 2\Flex SDK 2;C:\Program Files\Fle
            xModule
            PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
            PROCESSOR_ARCHITECTURE=x86
            PROCESSOR_IDENTIFIER=x86 Family 15 Model 3 Stepping 4, GenuineIntel
            PROCESSOR_LEVEL=15
            PROCESSOR_REVISION=0304
            ProgramFiles=C:\Program Files
            PROMPT=$P$G
            SESSIONNAME=Console
            SystemDrive=C:
            SystemRoot=C:\WINDOWS
            TEMP=C:\DOCUME~1\Owner\LOCALS~1\Temp
            TMP=C:\DOCUME~1\Owner\LOCALS~1\Temp
            USERDOMAIN=TAQUITO
            USERNAME=Owner
            USERPROFILE=C:\Documents and Settings\Owner
            VERITY_CFG=C:\CFusionMX7\verity\k2\common\verity.cfg
            windir=C:\WINDOWS
            Venu
            • 3. Re: Facing problem when requesting mxml
              Could you tell us what jre are you using? The Flex Module doesn't work on jre 1.4 .
              Regards,
              Catalin
              • 4. Re: Facing problem when requesting mxml
                mayabazar Level 1
                Hi Catalin,
                My JRE version is 1.5.0_11
                C:\Documents and Settings\Owner>java -version
                java version "1.5.0_11"
                Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_11-b03)
                Java HotSpot(TM) Client VM (build 1.5.0_11-b03, mixed mode, sharing)
                Venu
                • 5. Re: Facing problem when requesting mxml
                  I cannot reproduce your problem on my machine. Could you tell us what Flex Builder and FDS versions are you using? If you are using 2.0 upgrade to 2.0.1 and re-test the Flex Module.
                  Regards,
                  Catalin
                  • 6. Re: Facing problem when requesting mxml
                    JoseLuisTorresMontes
                    Hi guys,
                    I have the same problem. Any suggest, it seems that is not founding the JRE right?
                    JRE 1.5.0_11
                    Flex SDK ver 2
                    Flex Builder 2.0.143459
                    WinXP pro
                    Apache 2.2.3
                    • 7. Re: Facing problem when requesting mxml
                      Ivascu Cristian Level 1
                      Hi guys,
                      This issue is not related to the JRE used, but to the version of Flex 2 SDK. This error occurs because of some classes that were added in the 2.0.1 release and which are used by the compiler whenever doing any work.
                      Because of a bug we had in the installer, the version of SDK did not always validate correctly, and thus it allowed the module to be installed over a 2.0 SDK.
                      This can also occur due to alterations in the system classpath which point to an older version of mxmlc.jar.
                      To test if the version of SDK on which the module is installed, follow these steps:
                      1. Open a command prompt.
                      2. Browse to [sdk_folder]\bin
                      3. Run mxmlc.exe -version
                      The output should state Version 2.0.1.
                      Hope this helps,
                      Cristian
                      • 8. Re: Facing problem when requesting mxml
                        DannyDubroc
                        I downloaded the update for Version 2.0.1 and now I get :
                        Unable to create this part due to an internal error. Reason for the failure: The editor class could not be instantiated. This usually indicates that the editor's class name was mistyped in plugin.xml.
