4 Replies Latest reply on Nov 29, 2014 6:44 AM by joel_pau
    need background color for dynamic text
    vishymuku
      I am have ajax loaded dynamic text. I've kept overflow for text box "visible".
      width: 200px, height: 30px. Since overflow is visible, the text automatically expands (vertically).
      The problem comes when i want to use background color for the text. I used this:
      sym.$("textbox").css("background-color", "red");
      But this sets the color only for 30 px. and there will be extra text hanging without a background color. Increasing the height of the box to a fixed number is not a option - if the text is small there will empty colored space in the box.
      Is there a way to dynamically set the background color to the length of text?
      Any help will be much appreciated.
      Thanks in Advance.
        • 1. Re: need background color for dynamic text
          joel_pau Level 5
          Hello,
          You have to change color when loading is over. Here are some examples.
          Solution #1:
          $.ajax({
            type: "GET",
            url: "myfile.json",
            datatype: "json",
            success: function(datas){
            $.each(datas.matches, function(index,item){
            var matchs = sym.createChildSymbol("calendrier","saison");
            matchs.$("rencontre").html(item.leMatch);
          Solution #2:
          $.ajax({
            type: "GET",
            url: "myfile.json",
            datatype: "json",
          complete: function(){ sym.$("textbox").css("background-color", "red"); }
          Solution #3:
          $.ajax({
          type: "GET",
          //and so on
          }). done( sym.$("textbox").css("background-color", "red") );
          • 2. Re: need background color for dynamic text
            vishymuku Level 1
            Hi @joel_pau
            Thanks for the detailed options. I tried them, but none of them worked. They height of colored area remained same. (same as the one set when I initially set the text box size)
            I have tried another approach, by using a rectangle behind the text. I'll paste the code below. It works for me. Please let me know if it can be optimized.
            $.ajax({
                 type: "GET",
                 cache: false,
                 url: "httpp://example.com/get_message.php",
                 datatype: "json",
                 success: function(data){
                       console.log("data: ", data);
                        //message box is the text box created in EA
                       sym.$('messagebox').text(data[0].message);
                       //getting length of message
                        var strlen = data[0].message.length;
                       //given the font size and width of messagebox, only 12 characters can fit in a line
                        //getting number of lines required by dividing message length by 12
                       // multiplying by 50px for each line height
                      sym.$("messagebg").height(Math.ceil(strlen/12)*50+"px");
                      //starting the animation within this function
                      //when i tried it outside [$ajax({}).done( sym.play());]  images were only partially loaded.
                      sym.play();
                 error: function() { console.log("something went wrong"); }
            it'll be great if you can advice on the efficacy of using sym.play(); within the ajax process.
            cheers,
            • 3. Re: need background color for dynamic text
              joel_pau Level 5
              Here are 2 JSON demos: json Demos upgraded.zip - Box
              You can post your file. You can send me your file (private message).
              • 4. Re: need background color for dynamic text
                joel_pau Level 5
                I just updated the flickr file (download link).
