2 Replies Latest reply on Dec 4, 2014 1:24 AM by Henry 'Pi' James
    Need grep expression to change index page numbers
    saschriver63
      I built an Index using Type&Tables>Index however there was a lot of additional work that had to be done manually after it was built, so I do not want to use the Replace command. Is there a grep expression I could use in Find Change to find the "tab + page number" and replace with "tab + page number adding 2" (i.e., so an item originally indexed to be on page 13 would then be indexed on page 15).
