5 Replies Latest reply on Dec 1, 2014 12:31 PM by Jump_Over
    Label Script
    Cris Ider Level 1
      This script is for Adobe Indesign CS5 Windows.
      I´m trying change this script to acept this setup:
      Dispensing this dialog box and apply just if there is some selected image frame. (I think if there is no selected object, this will apply it to all image frame in page so I don´t wanna this couse I will use a shortcut to this script and accidents can occur)
      Sorry for long script.
      //LabelGraphics.jsx (Modified)
      //An InDesign CS3 JavaScript
      @@@BUILDINFO@@@ "LabelGraphics.jsx" 1.1.0 6-June-2008
      //Adds labels to the graphics in the active document.
      /* This sample script has been modified. The modications are listed here: option added to create a label from clipboard data,
        dropdown menu added to apply a swatch to the caption frame. This script can now apply lables to just the selected graphics
        if you have one or more images selected. Otherwise it will apply the lables to all graphics in the document. The hieght of the
        caption frame is determined by the amount of text, and paragraph style applied. the width of the caption frame is
        determined by the width of the graphic it is under. Setting the caption height in the dialog box has been removed, as it is no
        longer needed.
      main();
      function main(){
        if(app.documents.length != 0){
        if(app.documents.item(0).allGraphics.length != 0){
        myDisplayDialog();
        else{
        alert("Document contains no graphics.");
        else{
        alert("Please open a document and try again.");
      function myDisplayDialog(){
        var myLabelWidth = 100;
        var myStyleNames = myGetParagraphStyleNames();
        var mySwatchNames = myGetSwatchNames();
        var myDialog = app.dialogs.add({name:"LabelGraphics"});
        with(myDialog.dialogColumns.add()){
        //Label type
        with(dialogRows.add()){
        with(dialogColumns.add()){
        staticTexts.add({staticLabel:"Label Type", minWidth:myLabelWidth});
        var myLabelTypeDropdown = dropdowns.add({stringList:["File name", "File path", "XMP description", "XMP author","Paste from clipboard"], selectedIndex:4});
        staticTexts.add({staticLabel:"Label Offset", minWidth:myLabelWidth});
        var myLabelOffsetField = measurementEditboxes.add({editValue:0});
        //Style to apply
        staticTexts.add({staticLabel:"Label Style", minWidth:myLabelWidth});
        var myLabelStyleDropdown = dropdowns.add({stringList:myStyleNames, selectedIndex:0});
        //Swatch to apply
        staticTexts.add({staticLabel:"Apply swatch", minWidth:myLabelWidth});
        var mySwatchDropdown = dropdowns.add({stringList:mySwatchNames, selectedIndex:0});
        var myResult = myDialog.show();
        if(myResult == true){
        var myLabelType = myLabelTypeDropdown.selectedIndex;
        var myLabelHeight = 24; // A generic label height that will be adjusted later
        myPasteFailure = false;
        var myLabelOffset = myLabelOffsetField.editValue;
        var myLabelStyle = myStyleNames[myLabelStyleDropdown.selectedIndex];
        var mySwatch = mySwatchNames[mySwatchDropdown.selectedIndex];
        myDialog.destroy();
        var myOldXUnits = app.documents.item(0).viewPreferences.horizontalMeasurementUnits;
        var myOldYUnits = app.documents.item(0).viewPreferences.verticalMeasurementUnits;
        app.documents.item(0).viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
        app.documents.item(0).viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
        try{
        myAddLabels(myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, mySwatch);
        catch(e){
        alert("Unable to add lables. " + e);
        try{
        resizeOverset() ;
        catch(e){
        alert("Unable to correct overset text. " + e);
        if (myPasteFailure == true){
        alert("Unable to paste from clipboard.");
        app.documents.item(0).viewPreferences.horizontalMeasurementUnits = myOldXUnits;
        app.documents.item(0).viewPreferences.verticalMeasurementUnits = myOldYUnits;
        else{
        myDialog.destroy();
      function myAddLabels(myLabelType, myLabelHeight, myLabelOffset, myLabelStyleName, mySwatchName){
        var myDocument = app.documents.item(0);
        myStoriesArray = new Array();
        if (app.selection.length == 0) // If nothing is selected apply caption to all graphics in the document
        var myConfirmation = confirm("Add captions to all images in the document?", false, "LabelGraphics.jsx" );
        if (myConfirmation == true)
        var myGraphics = myDocument.allGraphics;
        else
        { // If graphics are selected, just add captions to the selected items, as long as they are rectangles(image frames)
        var myConfirmation = true;
        var mySelections = app.selection;
        myGraphics = new Array();
        for(i = 0; i < mySelections.length; i++){
        if(mySelections[i] == "[object Rectangle]"){   //Check to make sure selection only includes rectangles
        myGraphics.push(mySelections[i].allGraphics[0]);
        else{
        //alert("Objects other than graphics were selected!");
        //Nothing happens if you don't select at least one graphic
        myLabelStyle = myDocument.paragraphStyles.item(myLabelStyleName);
        mySwatch = myDocument.swatches.item(mySwatchName);
        if (myConfirmation == true){
        for(var myCounter = 0; myCounter < myGraphics.length; myCounter++){
        try{
        myAddLabel(myDocument, myGraphics[myCounter], myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, mySwatch, myStoriesArray);
        catch(e){};
      function myAddLabel(myDocument, myGraphic, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, mySwatch, myStoriesArray){
        var myLabel;
        var myLink = myGraphic.itemLink;
        var myPasteFromClipboard = false;
        //Create the label layer if it does not already exist.
        var myLabelLayer = myDocument.layers.item("labels");
        try{
        myLabelLayer.name;
        catch (myError){
        myLabelLayer = myDocument.layers.add({name:"labels"});
        //Label type defines the text that goes in the label.
        switch(myLabelType){
        //File name
        case 0:
        myLabel = myLink.name;
        break;
        //File path
        case 1:
        myLabel = myLink.filePath;
        break;
        //XMP description
        case 2:
        try{
        myLabel = myLink.linkXmp.description;
        catch(myError){
        myLabel = "No description available.";
        break;
        //XMP author
        case 3:
        try{
        myLabel = myLink.linkXmp.author
        catch(myError){
        myLabel = "No author available.";
        break;
        //Paste from the clipboard
        case 4:
        try{
        myPasteFromClipboard = true;
        catch(myError){
        myLabel = "No clipboard data available.";
        break;
        var myFrame = myGraphic.parent;
        myX1 = myFrame.geometricBounds[1];
        myY1 = myFrame.geometricBounds[2] + myLabelOffset;
        myX2 = myFrame.geometricBounds[3];
        myY2 = myY1 + myLabelHeight;
        if (myPasteFromClipboard ==true)
        try{
        var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{geometricBounds:[myY1, myX1, myY2, myX2]});
        myTextFrame.insertionPoints.item(0).select();
        app.paste();
        catch(e){
        myTextFrame.remove();
        myPasteFailure = true;
        else{
        var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{geometricBounds:[myY1, myX1, myY2, myX2], contents:myLabel});
        myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.leadingOffset;
        myTextFrame.paragraphs.item(0).appliedParagraphStyle = myLabelStyle;
        myTextFrame.fillColor = mySwatch;
        myFrameParentStory = myTextFrame.parentStory;
        myStoriesArray.push(myFrameParentStory);
      function myGetParagraphStyleNames(){
        var myStyleNames = app.documents.item(0).paragraphStyles.everyItem().name;
        return myStyleNames;
      function myGetSwatchNames(){
        var mySwatchNames = app.documents.item(0).swatches.everyItem().name;
        return mySwatchNames;
      function resizeOverset() {
                  for (var j = myStoriesArray.length - 1; j >= 0; j--) {
                          myLastFrame = myStoriesArray[j].texts[0].parentTextFrames[myStoriesArray[j].texts[0].parentTextFrames.l ength - 1];
        myNewY2 = myLastFrame.geometricBounds[3]; //get the width of the text frame before doing fit()
        myLastFrame.fit(FitOptions.FRAME_TO_CONTENT);
        myNewY1 = myLastFrame.geometricBounds[1];
        myNewX1 = myLastFrame.geometricBounds[2];
        myNewX2 = myLastFrame.geometricBounds[0];
        myLastFrame.geometricBounds = [myNewX1, myNewY1, myNewX2, myNewY2]; // reset the width to before fit() was ran
        • 1. Re: Label Script
          Jump_Over Level 5
          In case of empty selection this line is fired:
          so user can agree to continue (with document's all graphics as a target) or break.
          if you will modify it by assigning permanent "false" ==> script will break at this point.
          var myConfirmation = false;
          Jarek
          • 2. Re: Label Script
            Cris Ider Level 1
            Ok, it worked!
            But there is a way to hide dialog box accepting funcion?
            • 3. Re: Label Script
              Jump_Over Level 5
              Sorr, but I am not sure what your goal is...
              Jarek
              • 4. Re: Label Script
                Cris Ider Level 1
                My objective is apply this label automatic. When I select the image, play the script (by shortcut) and so appear the label without dialogbox. Similar a caption.
                • 5. Re: Re: Label Script
                  Jump_Over Level 5
                  Function runWithoutDialog() added - permanent sets inside:
                  //An InDesign CS5 JavaScript
                  @@@BUILDINFO@@@ "LabelGraphics.jsx" 1-Dec-2014
                  /* User interaction switched off
                    see settings inside runWithoutDialog() function
                  main();
                  function main(){
                    if(app.selection[0].allGraphics.length != 0){
                    runWithoutDialog(); // myDisplayDialog();
                    else{
                    alert("Select some frame with graphic");
                    else{
                  function runWithoutDialog(){
                    var myLabelType = 4; // paste from clipboard
                    var myLabelOffset = 0;
                    var myLabelStyle = myStyleNames[0];
                    var mySwatch = mySwatchNames[0];
                    try{
                    catch(e){
                    try{
                    resizeOverset() ;
                    catch(e){
                    //Label type
                    //Style to apply
                    //Swatch to apply
                    myDialog.destroy();
                    try{
                    catch(e){
                    try{
                    resizeOverset() ;
                    catch(e){
                    else{
                    myDialog.destroy();
                    var myConfirmation = false; // confirm("Add captions to all images in the document?", false, "LabelGraphics.jsx" );
                    else
                    else{
                    try{
                    catch(e){};
                    var myLabel;
                    try{
                    myLabelLayer.name;
                    catch (myError){
                    //File name
                    case 0:
                    break;
                    //File path
                    case 1:
                    break;
                    //XMP description
                    case 2:
                    try{
                    catch(myError){
                    break;
                    //XMP author
                    case 3:
                    try{
                    catch(myError){
                    break;
                    case 4:
                    try{
                    catch(myError){
                    break;
                    try{
                    app.paste();
                    catch(e){
                    else{
                    myLastFrame = myStoriesArray[j].texts[0].parentTextFrames[myStoriesArray[j].texts[0].parentTextFrames.length - 1];
