1. Re: Playback problem because of uninstalled codec
Ann Bens Nov 30, 2014 2:32 PM (in response to Glenhen)Download MediaInfo Windows and analyze a clip.
Post the outcome in treeview in a screendump.
This might give us some answers.
2. Re: Playback problem because of uninstalled codec
Greg Olsen Nov 30, 2014 4:03 PM (in response to Ann Bens)Thanks so much for your reply. If i understood what you said correctly here is the info from mediainfo:
General
Complete name : /Volumes/Seagate Backup Plus Drive 1/Ameidi Tzion/Media/Footage/Interviews_Day_2/Meedio Digital_1_2014-09-29_0659_C0000.mov
Format : QuickTime
Format/Info : Original Apple specifications
File size : 11.4 GiB
Duration : 15mn 40s
Overall bit rate : 104 Mbps
Encoded date : UTC 2014-09-29 10:59:56
Tagged date : UTC 2014-11-23 23:20:02
Writing library : Apple QuickTime
com.apple.proapps.manufacturer : Blackmagic Design
com.apple.proapps.cameraName : Meedio Digital
com.apple.proapps.clipID : Birds of the Wetlands
com.apple.proapps.logNote : This take has examples of grebes, pelicans, cormorants, long-legged wading birds and waterfowl.
com.blackmagic-design.cinemacamera.keywo : Wetlands, Grassy, Birds, Low Light, Sunset, Close Up, Flight
com.apple.proapps.reel : 1
com.apple.proapps.scene : 1
com.blackmagic-design.cinemacamera.shot : 1
com.apple.proapps.shot : 1
com.apple.proapps.angle : CU
com.blackmagic-design.cinemacamera.uuid : 244C1B4B76CD4C41A8178CD3F6E5533B
©TSC : 30000
©TSZ : 1001
Video
Format : ProRes
Format version : Version 0
Format profile : LT
Codec ID : apcs
Duration : 15mn 40s
Bit rate mode : Constant
Bit rate : 102 Mbps
Width : 1 888 pixels
Original width : 1 920 pixels
Height : 1 062 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:2
Scan type : Progressive
Bits/(Pixel*Frame) : 1.699
Stream size : 11.2 GiB (98%)
Writing library : bmd0
Language : English
Tagged date : UTC 2014-09-29 10:59:56
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
matrix_coefficients_Original : BT.709
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : in24
Duration : 15mn 40s
Bit rate : 2 304 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 258 MiB (2%)
Language : English
Other
Type : Time code
Format : QuickTime TC
Duration : 15mn 40s
Time code of first frame : 06:59:56:00
Time code settings : Striped
Language : English
3. Re: Playback problem because of uninstalled codec
Greg Olsen Nov 30, 2014 4:05 PM (in response to Greg Olsen)Sorry wrong thread.....
4. Re: Playback problem because of uninstalled codec
Ann Bens Dec 1, 2014 7:07 AM (in response to Glenhen)Please uncheck correct answer: its not.
5. Re: Playback problem because of uninstalled codec
Glenhen Dec 1, 2014 2:44 PM (in response to Ann Bens)Thanks Ann
Much appreciated.
Regards
Glen
6. Re: Playback problem because of uninstalled codec
Glenhen Dec 1, 2014 5:23 PM (in response to Greg Olsen)Thanks Greg. Much appreciated.
Glen
