1. Re: HTML in User Submitted Web App Custom Field BC Stripping Out
Liam Dilley Nov 30, 2014 11:58 PM (in response to Lynda Spangler)What is the custom field Lynda? Because multiline and string keep html formating
2. Re: HTML in User Submitted Web App Custom Field BC Stripping Out
Lynda Spangler Dec 1, 2014 3:42 PM (in response to Liam Dilley)The first was text string and then I tried multiline (textarea). If I submit the iFrame code into the form and click submit the iFrame code is gone.
Any ideas?
I ended up creating a temp solution where I use an input field for the iFrame, then I pull the src of the iFrame from the input field and insert it into the custom field. Then I just render the custom tag wrapped properly in an iFrame. Not the best but it is working for now until I can figure out what is going on.
3. Re: HTML in User Submitted Web App Custom Field BC Stripping Out
Liam Dilley Dec 1, 2014 3:44 PM (in response to Lynda Spangler)What browser as that is working perfectly fine here.
As a note those fields have character limits so if your trying to post A LOT of code, it would get stripped out because of that limitation.
4. Re: HTML in User Submitted Web App Custom Field BC Stripping Out
Lynda Spangler Dec 1, 2014 3:53 PM (in response to Liam Dilley)Firefox is the browser I was trying in. I will try it in Chrome to see if I can replicate it.
The iFrame I was posting was from YouTube so I don't believe the character limit was anywhere near the limit. The limit is 4000 characters, correct?
5. Re: HTML in User Submitted Web App Custom Field BC Stripping Out
Liam Dilley Dec 1, 2014 4:11 PM (in response to Lynda Spangler)You can PM me the code and I can try pasting it in or you can add my email as a user and I can have a look later if you want.
6. Re: HTML in User Submitted Web App Custom Field BC Stripping Out
Lynda Spangler Dec 1, 2014 5:58 PM (in response to Liam Dilley)I sent you a PM. Thank You!
