11 Replies Latest reply: Dec 2, 2014 2:32 AM by Michael MTT RSS
    keyboard shortcuts
    boxman2784 Community Member
      why is there no keyboard shortcuts? Even simple things like hitting space bar to play no longer work!
        • 1. Re: keyboard shortcuts
          Jon-M-Spear Community Member
          You're going to have to give us a LOT more information.
          PC/Mac
          Pr Version
          When they last worked
          etc, etc
          • 2. Re: keyboard shortcuts
            Peru Bob Community Member
            Change the batteries in your cordless keyboard.
            • 3. Re: keyboard shortcuts
              Imac
              yosemite
              premiere pro cc et al
              no keyboard shortcuts active. No presets in keyboard shortcuts menu
              • 4. Re: keyboard shortcuts
                I have just signed up to Adobe CC. Installed all the software and opened a new Premiere Pro project. Once I had imported all the footage I began my work for the day, selected a clip I wanted to work on, hit I to select an IN POINT and nothing happend, O for out point didn't work either. I then began to experiment with other keyboard shortcuts and none of them worked. I opened the keyboard shortcut menu and there is nothing in any of the the presets and there are no keys set for shortcuts in the default keyboard shortcut. So it seems my only options are to do everything by mouse or to set each shortcut manually, which will take far too much time!!
                • 5. Re: keyboard shortcuts
                  I can;t help you with Mac, but that really doesn't sound right.
                  I suggest a re-install, then reboot and try again.
                  • 7. Re: keyboard shortcuts
                    Ive already re-installed and then applied the cc updates and still nothing.
                    • 8. Re: keyboard shortcuts
                      Michael MTT Community Member
                      maybe you can just reimport the standart layout. Don't know exactly where they are on a mac? <drive>/Users/<user_name>/Library/Preferences/Adobe ...somewhere?
                      but you could find out like this: go to keyboardlayout, just asign one key and save the layout with a very special name to it, now search this file name with the finder. should be a file with .kys ending. If you find that folder we could send you the standart Layout to import.
                      • 9. Re: keyboard shortcuts
                        A few other threads have mentioned importing the .kys into CC but I don't have the original .kys file for the standard shortcut layout if that makes any sense?
                        • 10. Re: keyboard shortcuts
                          but did you find the folder? I send you a pm with a link. You could also try to copy the following xml structure into a textoc and rename it "Adobe Premiere Pro Custom.kys"
                          <?xml version="1.0" encoding="UTF-8"?>
                          <PremiereData Version="3">
                          <shortcuts Version="4">
                          <context.StoryPanel Version="1">
                          <itemcount>0</itemcount>
                          </context.StoryPanel>
                          <context.effectcontrols Version="1">
                          <item.0 Version="1">
                          <commandname>cmd.edit.clear</commandname>
                          <modifier.shift>false</modifier.shift>
                          <modifier.alt>false</modifier.alt>
                          <modifier.ctrl>false</modifier.ctrl>
                          <virtualkey>8</virtualkey>
                          </item.0>
                          <itemcount>1</itemcount>
                          </context.effectcontrols>
                          <context.edittotape Version="1">
                          </context.edittotape>
                          <context.mediabrowser Version="1">
                          <item.1 Version="1">
                          <commandname>cmd.mediabrowser.selectdirectorylist</commandname>
                          <virtualkey>37</virtualkey>
                          </item.1>
                          <item.2 Version="1">
                          <commandname>cmd.mediabrowser.selectmedialist</commandname>
                          <virtualkey>39</virtualkey>
                          </item.2>
                          <commandname>cmd.mediabrowser.openinsourcemonitor</commandname>
                          <modifier.shift>true</modifier.shift>
                          <virtualkey>79</virtualkey>
                          </item.0>
                          <itemcount>3</itemcount>
                          </context.mediabrowser>
                          <context.source.monitor Version="1">
                          </context.source.monitor>
                          <context.program.monitor Version="1">
                          </context.program.monitor>
                          <context.audioclipmixer Version="1">
                          </context.audioclipmixer>
                          <context.audiomixer Version="1">
                          <commandname>cmd.audiomixer.showhidetracks</commandname>
                          <modifier.alt>true</modifier.alt>
                          <modifier.ctrl>true</modifier.ctrl>
                          <virtualkey>84</virtualkey>
                          </item.1>
                          <commandname>cmd.audiomixer.meterinput</commandname>
                          <virtualkey>73</virtualkey>
                          </item.0>
                          <itemcount>2</itemcount>
                          </context.audiomixer>
                          <context.metadata_editor Version="1">
                          <commandname>cmd.metadataeditor.play</commandname>
                          <virtualkey>32</virtualkey>
                          </item.0>
                          </context.metadata_editor>
                          <context.progress Version="1">
                          </context.progress>
                          <context.timeline Version="1">
                          <item.8 Version="1">
                          <commandname>cmd.timeline.slide.left.one</commandname>
                          </item.8>
                          <item.15 Version="1">
                          <commandname>cmd.timeline.slip.right.several</commandname>
                          </item.15>
                          <commandname>cmd.timeline.nudge.left.one</commandname>
                          <virtualkey>188</virtualkey>
                          </item.1>
                          <item.11 Version="1">
                          <commandname>cmd.timeline.slide.right.several</commandname>
                          </item.11>
                          <item.9 Version="1">
                          <commandname>cmd.timeline.slide.left.several</commandname>
                          </item.9>
                          <commandname>cmd.timeline.nudge.left.several</commandname>
                          </item.2>
                          </item.0>
                          <item.13 Version="1">
                          <commandname>cmd.timeline.slip.left.several</commandname>
                          </item.13>
                          <item.5 Version="1">
                          <commandname>cmd.timeline.ripple.delete</commandname>
                          </item.5>
                          <item.14 Version="1">
                          <commandname>cmd.timeline.slip.right.one</commandname>
                          </item.14>
                          <item.3 Version="1">
                          <commandname>cmd.timeline.nudge.right.one</commandname>
                          <virtualkey>190</virtualkey>
                          </item.3>
                          <item.12 Version="1">
                          <commandname>cmd.timeline.slip.left.one</commandname>
                          </item.12>
                          <item.7 Version="1">
                          <commandname>cmd.timeline.show.previous.screen</commandname>
                          <virtualkey>38</virtualkey>
                          </item.7>
                          <item.16 Version="1">
                          <commandname>cmd.timeline.workbar.set.in</commandname>
                          <virtualkey>192</virtualkey>
                          </item.16>
                          <item.4 Version="1">
                          <commandname>cmd.timeline.nudge.right.several</commandname>
                          </item.4>
                          <item.6 Version="1">
                          <commandname>cmd.timeline.show.next.screen</commandname>
                          <virtualkey>40</virtualkey>
                          </item.6>
                          <item.10 Version="1">
                          <commandname>cmd.timeline.slide.right.one</commandname>
                          </item.10>
                          <item.17 Version="1">
                          <commandname>cmd.timeline.workbar.set.out</commandname>
                          <virtualkey>222</virtualkey>
                          </item.17>
                          <itemcount>18</itemcount>
                          </context.timeline>
                          <context.captions Version="1">
                          </context.captions>
                          <context.capture Version="1">
                          <commandname>cmd.capture.step.back</commandname>
                          </item.8>
                          <commandname>cmd.capture.fastforward</commandname>
                          <virtualkey>70</virtualkey>
                          </item.1>
                          <commandname>cmd.capture.step.forward</commandname>
                          </item.9>
                          <commandname>cmd.capture.fastrewind</commandname>
                          <virtualkey>82</virtualkey>
                          </item.2>
                          <commandname>cmd.capture.eject</commandname>
                          <virtualkey>69</virtualkey>
                          </item.0>
                          <commandname>cmd.capture.record</commandname>
                          <virtualkey>71</virtualkey>
                          </item.5>
                          <commandname>cmd.capture.goto.inpoint</commandname>
                          <virtualkey>81</virtualkey>
                          </item.3>
                          <commandname>cmd.capture.record.video</commandname>
                          <virtualkey>86</virtualkey>
                          </item.7>
                          <commandname>cmd.capture.goto.outpoint</commandname>
                          <virtualkey>87</virtualkey>
                          </item.4>
                          <commandname>cmd.capture.record.audio</commandname>
                          <virtualkey>65</virtualkey>
                          </item.6>
                          <commandname>cmd.capture.stop</commandname>
                          <virtualkey>83</virtualkey>
                          </item.10>
                          <itemcount>11</itemcount>
                          </context.capture>
                          <context.titler Version="1">
                          <item.29 Version="1">
                          <commandname>cmd.titler.misc.tool.rectangle</commandname>
                          </item.29>
                          <item.24 Version="1">
                          <commandname>cmd.titler.misc.size.one.inc</commandname>
                          </item.24>
                          <item.31 Version="1">
                          <commandname>cmd.titler.misc.tool.select</commandname>
                          </item.31>
                          <item.32 Version="1">
                          <commandname>cmd.titler.misc.tool.type</commandname>
                          </item.32>
                          <item.25 Version="1">
                          <commandname>cmd.titler.misc.tool.arc</commandname>
                          </item.25>
                          <item.23 Version="1">
                          <commandname>cmd.titler.misc.size.one.dec</commandname>
                          </item.23>
                          <item.34 Version="1">
                          <commandname>cmd.titler.misc.tool.wedge</commandname>
                          </item.34>
                          <commandname>cmd.titler.misc.lead.one.inc</commandname>
                          </item.8>
                          <commandname>cmd.titler.misc.nudge.one.right</commandname>
                          </item.15>
                          <commandname>cmd.titler.misc.kern.five.dec</commandname>
                          </item.1>
                          <commandname>cmd.titler.misc.nudge.five.right</commandname>
                          </item.11>
                          <item.30 Version="1">
                          <commandname>cmd.titler.misc.tool.rotation</commandname>
                          </item.30>
                          <item.26 Version="1">
                          <commandname>cmd.titler.misc.tool.ellipse</commandname>
                          </item.26>
                          <commandname>cmd.titler.misc.nudge.five.down</commandname>
                          </item.9>
                          <commandname>cmd.titler.misc.kern.five.inc</commandname>
                          </item.2>
                          <commandname>cmd.titler.misc.copyright</commandname>
                          <virtualkey>67</virtualkey>
                          </item.0>
                          <item.28 Version="1">
                          <commandname>cmd.titler.misc.tool.pen</commandname>
                          <virtualkey>80</virtualkey>
                          </item.28>
                          <commandname>cmd.titler.misc.nudge.one.down</commandname>
                          </item.13>
                          <item.27 Version="1">
                          <commandname>cmd.titler.misc.tool.line</commandname>
                          <virtualkey>76</virtualkey>
                          </item.27>
                          <item.21 Version="1">
                          <commandname>cmd.titler.misc.size.five.dec</commandname>
                          </item.21>
                          <item.33 Version="1">
                          <commandname>cmd.titler.misc.tool.type.vertical</commandname>
                          </item.33>
                          <commandname>cmd.titler.misc.lead.five.dec</commandname>
                          </item.5>
                          <commandname>cmd.titler.misc.nudge.one.left</commandname>
                          </item.14>
                          <commandname>cmd.titler.misc.kern.one.dec</commandname>
                          </item.3>
                          <commandname>cmd.titler.misc.nudge.five.up</commandname>
                          </item.12>
                          <commandname>cmd.titler.misc.lead.one.dec</commandname>
                          </item.7>
                          <commandname>cmd.titler.misc.nudge.one.up</commandname>
                          </item.16>
                          <item.19 Version="1">
                          <commandname>cmd.titler.misc.position.top.titlesafe</commandname>
                          </item.19>
                          <item.20 Version="1">
                          <commandname>cmd.titler.misc.registered</commandname>
                          </item.20>
                          <commandname>cmd.titler.misc.kern.one.inc</commandname>
                          </item.4>
                          <commandname>cmd.titler.misc.lead.five.inc</commandname>
                          </item.6>
                          <commandname>cmd.titler.misc.nudge.five.left</commandname>
                          </item.10>
                          <item.18 Version="1">
                          <commandname>cmd.titler.misc.position.left.titlesafe</commandname>
                          </item.18>
                          <item.22 Version="1">
                          <commandname>cmd.titler.misc.size.five.inc</commandname>
                          </item.22>
                          <commandname>cmd.titler.misc.position.bottom.titlesafe</commandname>
                          <virtualkey>68</virtualkey>
                          </item.17>
                          <itemcount>35</itemcount>
                          </context.titler>
                          <context.project Version="1">
                          <commandname>cmd.project.move.up</commandname>
                          </item.8>
                          <commandname>cmd.project.nextcolumnfield</commandname>
                          <virtualkey>9</virtualkey>
                          </item.15>
                          <commandname>cmd.project.deletewithoptions</commandname>
                          <virtualkey>46</virtualkey>
                          </item.1>
                          <commandname>cmd.project.moveextend.right</commandname>
                          </item.11>
                          <commandname>cmd.project.moveextend.down</commandname>
                          </item.9>
                          <commandname>cmd.project.move.down</commandname>
                          </item.2>
                          </item.0>
                          <commandname>cmd.project.movel.eft</commandname>
                          </item.13>
                          <commandname>cmd.project.wingtip.view.icon</commandname>
                          <virtualkey>34</virtualkey>
                          </item.21>
                          <commandname>cmd.project.move.pagedown</commandname>
                          </item.5>
                          <commandname>cmd.project.next.thumbnail.size.large</commandname>
                          </item.14>
                          <commandname>cmd.project.move.end</commandname>
                          <virtualkey>35</virtualkey>
                          </item.3>
                          <commandname>cmd.project.moveextend.up</commandname>
                          </item.12>
                          <commandname>cmd.project.move.right</commandname>
                          </item.7>
                          <commandname>cmd.project.nextrowfield</commandname>
                          <virtualkey>13</virtualkey>
                          </item.16>
                          <commandname>cmd.project.previousrowfield</commandname>
                          </item.19>
                          <commandname>cmd.project.toggle.view</commandname>
                          <virtualkey>191</virtualkey>
                          </item.20>
                          <commandname>cmd.project.move.home</commandname>
                          <virtualkey>36</virtualkey>
                          </item.4>
                          <commandname>cmd.project.move.pageup</commandname>
                          <virtualkey>33</virtualkey>
                          </item.6>
                          <commandname>cmd.project.moveextend.left</commandname>
                          </item.10>
                          <commandname>cmd.project.previouscolumnfield</commandname>
                          </item.18>
                          <commandname>cmd.project.wingtip.view.list</commandname>
                          </item.22>
                          <commandname>cmd.project.previous.thumbnail.size.large</commandname>
                          </item.17>
                          <itemcount>23</itemcount>
                          </context.project>
                          <context.global Version="1">
                          <commandname>cmd.file.importfrombrowser</commandname>
                          </item.29>
                          <commandname>cmd.file.batchcapture</commandname>
                          <virtualkey>117</virtualkey>
                          </item.24>
                          <commandname>cmd.file.new.project</commandname>
                          <virtualkey>78</virtualkey>
                          </item.31>
                          <commandname>cmd.file.new.sequence</commandname>
                          </item.32>
                          <item.40 Version="1">
                          <commandname>cmd.marker.clearclipmarker.all</commandname>
                          <virtualkey>48</virtualkey>
                          </item.40>
                          <item.54 Version="1">
                          <commandname>cmd.sequence.applydefaultvideotransition</commandname>
                          </item.54>
                          <commandname>cmd.file.browse</commandname>
                          </item.25>
                          <commandname>cmd.edit.undo</commandname>
                          <virtualkey>90</virtualkey>
                          </item.23>
                          <item.62 Version="1">
                          <commandname>cmd.sequence.rippletrimpreviousedittoplayhead</commandname>
                          </item.62>
                          <commandname>cmd.file.properties.selection</commandname>
                          <virtualkey>72</virtualkey>
                          </item.34>
                          <item.84 Version="1">
                          <commandname>cmd.tools.01pointer</commandname>
                          </item.84>
                          <item.53 Version="1">
                          <commandname>cmd.sequence.applydefaultaudiotransition</commandname>
                          </item.53>
                          <item.94 Version="1">
                          <commandname>cmd.transport.selectedclip.start</commandname>
                          </item.94>
                          <item.125 Version="1">
                          <commandname>uif.window.Timelines</commandname>
                          <virtualkey>51</virtualkey>
                          </item.125>
                          <commandname>cmd.common.setout</commandname>
                          </item.8>
                          <item.101 Version="1">
                          <commandname>cmd.transport.shuttle.stop</commandname>
                          <virtualkey>75</virtualkey>
                          </item.101>
                          <item.119 Version="1">
                          <commandname>uif.window.Effect Controls</commandname>
                          <virtualkey>53</virtualkey>
                          </item.119>
                          <item.41 Version="1">
                          <commandname>cmd.marker.clearclipmarker.current</commandname>
                          </item.41>
                          <item.75 Version="1">
                          <commandname>cmd.tlnav.reveal.nested.sequence</commandname>
                          </item.75>
                          <item.118 Version="1">
                          <commandname>uif.window.Audio Mixers</commandname>
                          <virtualkey>54</virtualkey>
                          </item.118>
                          <item.68 Version="1">
                          <commandname>cmd.titler.menu.tabstops</commandname>
                          </item.68>
                          <item.64 Version="1">
                          <commandname>cmd.set.marker</commandname>
                          <virtualkey>77</virtualkey>
                          </item.64>
                          <item.37 Version="1">
                          <commandname>cmd.file.savecopy</commandname>
                          </item.37>
                          <item.70 Version="1">
                          <commandname>cmd.titler.menu.type.centre</commandname>
                          </item.70>
                          <item.92 Version="1">
                          <commandname>cmd.transport.play.fat</commandname>
                          </item.92>
                          <item.83 Version="1">
                          <commandname>cmd.toggle.maximize.frame</commandname>
                          <virtualkey>186</virtualkey>
                          </item.83>
                          <item.114 Version="1">
                          <commandname>cmd.window.user.workspace.7</commandname>
                          <virtualkey>56</virtualkey>
                          </item.114>
                          <item.45 Version="1">
                          <commandname>cmd.marker.gotoclipmarker.previous</commandname>
                          </item.45>
                          <item.107 Version="1">
                          <commandname>cmd.window.user.workspace.0</commandname>
                          <virtualkey>49</virtualkey>
                          </item.107>
                          <item.71 Version="1">
                          <commandname>cmd.titler.menu.type.left</commandname>
                          </item.71>
                          <item.73 Version="1">
                          <commandname>cmd.tlnav.next.edit</commandname>
                          </item.73>
                          <item.122 Version="1">
                          <commandname>uif.window.Program Monitors</commandname>
                          <virtualkey>52</virtualkey>
                          </item.122>
                          <item.47 Version="1">
                          <commandname>cmd.marker.gotosequencemarker.previous</commandname>
                          </item.47>
                          <item.61 Version="1">
                          <commandname>cmd.sequence.rippletrimnextedittoplayhead</commandname>
                          </item.61>
                          <item.110 Version="1">
                          <commandname>cmd.window.user.workspace.3</commandname>
                          </item.110>
                          <commandname>cmd.edit.find</commandname>
                          </item.15>
                          <item.82 Version="1">
                          <commandname>cmd.tlnav.zoomto.sequence</commandname>
                          </item.82>
                          <item.89 Version="1">
                          <commandname>cmd.tools.08slide</commandname>
                          <virtualkey>85</virtualkey>
                          </item.89>
                          <item.111 Version="1">
                          <commandname>cmd.window.user.workspace.4</commandname>
                          </item.111>
                          <item.80 Version="1">
                          <commandname>cmd.tlnav.toggle.target.audio.1</commandname>
                          </item.80>
                          <item.56 Version="1">
                          <commandname>cmd.sequence.lift</commandname>
                          </item.56>
                          <item.49 Version="1">
                          <commandname>cmd.marker.setsequenceinoutmarkeraroundtargetclip</commandname>
                          <virtualkey>220</virtualkey>
                          </item.49>
                          <item.102 Version="1">
                          <commandname>cmd.transport.step.back</commandname>
                          </item.102>
                          <item.66 Version="1">
                          <commandname>cmd.titler.menu.select.nextdown</commandname>
                          </item.66>
                          <commandname>cmd.clip.insert</commandname>
                          </item.1>
                          <item.74 Version="1">
                          <commandname>cmd.tlnav.prev.edit</commandname>
                          </item.74>
                          <item.38 Version="1">
                          <commandname>cmd.goto.out</commandname>
                          </item.38>
                          <item.104 Version="1">
                          <commandname>cmd.transport.step.forward</commandname>
                          </item.104>
                          <item.55 Version="1">
                          <commandname>cmd.sequence.findprevioustrackgap</commandname>
                          </item.55>
                          <item.90 Version="1">
                          <commandname>cmd.tools.11zoom</commandname>
                          </item.90>
                          <item.60 Version="1">
                          <commandname>cmd.sequence.razorateditline.all</commandname>
                          </item.60>
                          <item.81 Version="1">
                          <commandname>cmd.tlnav.toggle.target.video.1</commandname>
                          </item.81>
                          <item.72 Version="1">
                          <commandname>cmd.titler.menu.type.right</commandname>
                          </item.72>
                          <item.76 Version="1">
                          <commandname>cmd.tlnav.select.clip.at.playhead</commandname>
                          </item.76>
                          <item.77 Version="1">
                          <commandname>cmd.tlnav.select.next.clip</commandname>
                          </item.77>
                          <item.69 Version="1">
                          <commandname>cmd.titler.menu.templates</commandname>
                          <virtualkey>74</virtualkey>
                          </item.69>
                          <item.123 Version="1">
                          <commandname>uif.window.Projects</commandname>
                          </item.123>
                          <commandname>cmd.edit.cut</commandname>
                          <virtualkey>88</virtualkey>
                          </item.11>
                          <item.98 Version="1">
                          <commandname>cmd.transport.shuttle.right</commandname>
                          </item.98>
                          <commandname>cmd.file.new.bin</commandname>
                          </item.30>
                          <commandname>cmd.file.capture</commandname>
                          <virtualkey>116</virtualkey>
                          </item.26>
                          <item.95 Version="1">
                          <commandname>cmd.transport.sequence.end</commandname>
                          </item.95>
                          <item.48 Version="1">
                          <commandname>cmd.marker.setsequenceinoutmarkeraroundselection.out</commandname>
                          </item.48>
                          <item.85 Version="1">
                          <commandname>cmd.tools.02trackselectforward</commandname>
                          </item.85>
                          </item.9>
                          <item.58 Version="1">
                          <commandname>cmd.sequence.preview</commandname>
                          </item.58>
                          <item.97 Version="1">
                          <commandname>cmd.transport.shuttle.left</commandname>
                          </item.97>
                          <item.86 Version="1">
                          <commandname>cmd.tools.04roll</commandname>
                          </item.86>
                          <item.65 Version="1">
                          <commandname>cmd.titler.menu.arrange.back</commandname>
                          </item.65>
                          <item.109 Version="1">
                          <commandname>cmd.window.user.workspace.2</commandname>
                          </item.109>
                          <item.46 Version="1">
                          <commandname>cmd.marker.gotosequencemarker.next</commandname>
                          </item.46>
                          <item.120 Version="1">
                          <commandname>uif.window.Effects</commandname>
                          <virtualkey>55</virtualkey>
                          </item.120>
                          <commandname>cmd.clip.linkaudioandvideo</commandname>
                          </item.2>
                          <commandname>cmd.clip.group</commandname>
                          </item.0>
                          <item.67 Version="1">
                          <commandname>cmd.titler.menu.select.nextup</commandname>
                          </item.67>
                          <item.57 Version="1">
                          <commandname>cmd.sequence.matchframe</commandname>
                          </item.57>
                          <item.43 Version="1">
                          <commandname>cmd.marker.clearsequencemarker.current</commandname>
                          </item.43>
                          <item.36 Version="1">
                          <commandname>cmd.file.saveas</commandname>
                          </item.36>
                          <item.100 Version="1">
                          <commandname>cmd.transport.shuttle.slow.right</commandname>
                          </item.100>
                          <item.105 Version="1">
                          <commandname>cmd.transport.step.forward.five</commandname>
                          <virtualkey>50</virtualkey>
                          </item.105>
                          <item.42 Version="1">
                          <commandname>cmd.marker.clearsequencemarker.all</commandname>
                          </item.42>
                          <item.91 Version="1">
                          <commandname>cmd.transport.play.ctitoout</commandname>
                          </item.91>
                          <item.52 Version="1">
                          <commandname>cmd.select.previous.panel</commandname>
                          </item.52>
                          <commandname>cmd.file.import</commandname>
                          </item.28>
                          <commandname>cmd.edit.duplicate</commandname>
                          </item.13>
                          <item.93 Version="1">
                          <commandname>cmd.transport.selectedclip.end</commandname>
                          </item.93>
                          <item.112 Version="1">
                          <commandname>cmd.window.user.workspace.5</commandname>
                          </item.112>
                          <item.35 Version="1">
                          <commandname>cmd.file.save</commandname>
                          </item.35>
                          <item.63 Version="1">
                          <commandname>cmd.sequence.snap</commandname>
                          </item.63>
                          <commandname>cmd.file.export.movie</commandname>
                          </item.27>
                          <item.117 Version="1">
                          <commandname>cmd.zoom.out</commandname>
                          </item.117>
                          <commandname>cmd.edit.rippledelete</commandname>
                          <virtualkey>66</virtualkey>
                          </item.21>
                          <item.79 Version="1">
                          <commandname>cmd.tlnav.toggle.all.target.video</commandname>
                          </item.79>
                          <commandname>cmd.file.new.title</commandname>
                          </item.33>
                          <item.59 Version="1">
                          <commandname>cmd.sequence.razorateditline</commandname>
                          </item.59>
                          <item.121 Version="1">
                          <commandname>uif.window.Media Browser</commandname>
                          </item.121>
                          <item.88 Version="1">
                          <commandname>cmd.tools.06razor</commandname>
                          <virtualkey>89</virtualkey>
                          </item.88>
                          <commandname>cmd.clip.ungroup</commandname>
                          </item.5>
                          <item.96 Version="1">
                          <commandname>cmd.transport.sequence.start</commandname>
                          </item.96>
                          <item.106 Version="1">
                          <commandname>cmd.transport.toggleplay</commandname>
                          </item.106>
                          <item.51 Version="1">
                          <commandname>cmd.select.next.panel</commandname>
                          </item.51>
                          <item.78 Version="1">
                          <commandname>cmd.tlnav.select.previous.clip</commandname>
                          </item.78>
                          <commandname>cmd.edit.editoriginal</commandname>
                          </item.14>
                          <commandname>cmd.clip.overlay</commandname>
                          </item.3>
                          <commandname>cmd.edit.deselectall</commandname>
                          </item.12>
                          <commandname>cmd.common.setin</commandname>
                          </item.7>
                          <item.50 Version="1">
                          <commandname>cmd.select.find.box</commandname>
                          </item.50>
                          <commandname>cmd.edit.paste</commandname>
                          </item.16>
                          <commandname>cmd.edit.preferences.userinterface</commandname>
                          <virtualkey>120</virtualkey>
                          </item.19>
                          <commandname>cmd.edit.redo</commandname>
                          </item.20>
                          <commandname>cmd.clip.speed</commandname>
                          </item.4>
                          <commandname>cmd.clip.videooptions.field</commandname>
                          </item.6>
                          <item.124 Version="1">
                          <commandname>uif.window.Source Monitors</commandname>
                          </item.124>
                          <item.108 Version="1">
                          <commandname>cmd.window.user.workspace.1</commandname>
                          </item.108>
                          <commandname>cmd.edit.copy</commandname>
                          </item.10>
                          <item.44 Version="1">
                          <commandname>cmd.marker.gotoclipmarker.next</commandname>
                          </item.44>
                          <item.115 Version="1">
                          <commandname>cmd.window.user.workspace.8</commandname>
                          <virtualkey>57</virtualkey>
                          </item.115>
                          <item.113 Version="1">
                          <commandname>cmd.window.user.workspace.6</commandname>
                          </item.113>
                          <commandname>cmd.edit.pasteinsert</commandname>
                          </item.18>
                          <item.39 Version="1">
                          <commandname>cmd.help.contents</commandname>
                          <virtualkey>112</virtualkey>
                          </item.39>
                          <item.116 Version="1">
                          <commandname>cmd.zoom.in</commandname>
                          </item.116>
                          <commandname>cmd.edit.selectall</commandname>
                          </item.22>
                          <commandname>cmd.edit.pasteattributes</commandname>
                          </item.17>
                          <item.103 Version="1">
                          <commandname>cmd.transport.step.back.five</commandname>
                          </item.103>
                          <item.87 Version="1">
                          <commandname>cmd.tools.05ratestretch</commandname>
                          </item.87>
                          <item.99 Version="1">
                          <commandname>cmd.transport.shuttle.slow.left</commandname>
                          </item.99>
                          <itemcount>126</itemcount>
                          </context.global>
                          <context.history Version="1">
                          <commandname>cmd.history.step.backward</commandname>
                          </item.1>
                          <commandname>cmd.history.step.forward</commandname>
                          </item.2>
                          </item.0>
                          </context.history>
                          <context.effects Version="1">
                          <commandname>cmd.effects.createcustomfolder</commandname>
                          </item.1>
                          </item.0>
                          </context.effects>
                          <context.timecode Version="1">
                          </context.timecode>
                          <platform>windows</platform>
                          </shortcuts>
                          </PremiereData>
                          • 11. Re: keyboard shortcuts
                            Maybe this newer thread might help. seems to be a bug about permission conflict on mac.
                            Keyboard not responsive on Mac
