9 Replies Latest reply on Mar 13, 2007 5:10 AM by ggshow
    Extract a number from a number
    millja Level 1
      I've got a 5 digit number, for example 12345. I want to extract the second last number, in the example it would be 4. I'm sure there's a way to do this, but i don't know which phrase to use when i google. Can anyone please help me? Thanks!!
        • 1. Re: Extract a number from a number
          Level 7
          millja,
          If I had to do this, I would convert that number to a string and use
          String methods on it.
          var n:Number = 12345;
          var s:String = n.toString();
          trace(s.charAt(3));
          In the above, the variable n represents your original number. The s
          variable is that same number, as a string. Finally, the String.charAt()
          method is fed a parameter of 3 to pull out the fourth character from that
          string. Why does 3 pull out character four? This is just "one of those
          things" you have to get used to with programming. In many cases,
          ActionScript counts series of things from zero, rather than one. So 0 is
          the first, 1 is the second, and so on.
          You can see for yourself in the String.charAt() entry of the
          ActionScript 2.0 Language Reference. See the "String class" entry itself
          for other string methods (methods are a things a particular object can do;
          properties are the characteristics it has and events are the things it can
          react to).
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Extract a number from a number
            BorosAdam Level 1
            for example you can convert the number to string, than create a substring of it extracting the requested digits and then create a number again from that string. :) you can write a flexible function for this task, something like the following... (you can copy the whole code below to an empty flash document into the first frame as a frame action and just test the movie to see results in the trace panel)
            • 3. Re: Extract a number from a number
              millja Level 1
              Thank you! It really helped me a lot :)
              • 4. Re: Extract a number from a number
                ggshow Level 2
                how about this
                num1 = 12345;
                num2 = Math.floor((num1%100)/10);
                trace(num2);
                • 5. Re: Extract a number from a number
                  BorosAdam Level 1
                  ok, this works - in this special case and maybe in some other cases too still it's not a good solution because it works only in special cases! the function i submitted is more generic and uses no math therefore it returns the correct digit(s) in every case! think about it or try your code with other combination of digits to see what i mean.
                  adam
                  • 6. Re: Extract a number from a number
                    Marghoob Suleman Level 1
                    i think ggshow's method is great!
                    very short... very logical...
                    • 7. Re: Extract a number from a number
                      mclem Level 1
                      If you always want the second to last digit no matter how long the number is the easiest way is to cast the number to a string and use the substr() function with a negative parameter for the start and a length of 1 like so:
                      var someNumber:Number = 12345;
                      var tempString:String = someNumber.toString();
                      trace(tempString.substr(-2,1)); //output: 4
                      a negative start number will start the substring from the end of the string instead of the beginning
                      markc
                      • 8. Re: Extract a number from a number
                        BorosAdam Level 1
                        aghh... ok! i see now!! :) i was fool a bit! gg's code is good for every case if you want to extract the second last digit. ok, nice one. ;)
                        adam
                        • 9. Re: Extract a number from a number
                          ggshow Level 2
                          or this:
                          num1 = 12345;
                          num2 = Math.floor(num1/10%10);
                          trace(num2);
