1 Reply Latest reply on Dec 5, 2014 2:32 AM by steverocket2
    Export selectd text as a jpeg
    balagluck
      Please review my code, i am not able to get all the indesign files information as per my code, i can export only first two files, then the loop repeatedly process the second file only,not getting 3rd and 4th...., Please advice.
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
      app.jpegExportPreferences.jpegQuality = JPEGOptionsQuality.MAXIMUM;
      app.jpegExportPreferences.exportResolution = 300;
      app.jpegExportPreferences.jpegColorSpace = JpegColorSpaceEnum.RGB;
      app.jpegExportPreferences.jpegRenderingStyle = JPEGOptionsFormat .BASELINE_ENCODING;
      var myFolder=Folder.selectDialog("Select Indesign Folder");
      var myInddFiles=myFolder.getFiles("*.indd");
      for(i=0; i<myInddFiles.length; i++){
         var myDoc=app.open (myInddFiles[i]);
         var myRuleSet = new Array (new sample);
          with (myDoc){
          var element = xmlElements;
          __processRuleSet (element[0], myRuleSet);
      function sample(){
          this.name = "sample";
          this.xpath = '//*[@font="Medicine Symbols 1"]';
          this.apply = function (myElement, myRuleProcessor){
           with(myElement){
            var myframe = myDoc.pages[0].textFrames.add();
              myElement.placeXML(myframe);
              myframe.fit(FitOptions.FRAME_TO_CONTENT);
              myframe.select();
              imageName = myElement.xmlAttributes.item('id').value+''
              $.writeln (filepath = myFolder+"/"+imageName+".jpg");
              myframe.exportFile(ExportFormat.JPG,new File(filepath), false);
      myDoc.close(SaveOptions.NO);
        • 1. Re: Export selectd text as a jpeg
          steverocket2 Level 1
          I would not do the export of the frame within an XML rule.
          Without the export InDesign will create more than two frames.
          function sample(){
               with(myElement){
                  //myframe.select();
                  //var imageName = myElement.xmlAttributes.item('id').value''
                  //$.writeln (filepath = myFolder+"/"+imageName+".jpg");
                  //myframe.exportFile(ExportFormat.JPG, new File(filepath), false);
          thanks Stefan
