0 Replies Latest reply on Mar 13, 2007 3:42 AM by WardLoockx
    ExternalInterface call works in firefox not in IE7
    WardLoockx
      Hello,
      I have 2calls in my flex application to Javascript functions. The first call (in different file), works fine in IE7 and firefox. The second only works in firefox. I have been debugging using trace but can't find the problem.
      The following code is the function call.
      quote:
      private function getUserID():String
      var id:String;
      //trace('binnen functie');
      if (ExternalInterface.available)
      //trace('available');
      var wrapperFunction:String = "getID";
      id = ExternalInterface.call(wrapperFunction);
      //trace('gevonden id: '+id);
      else
      id = "Wrapper not available";
      return id;
      The following code is the Javascript function that is called.
      quote:
      function getID()
      return 2626
      </script>
      Thanks in advance,
      Ward Loockx
