7 Replies Latest reply on Dec 12, 2014 1:58 AM by Stamm
    How to delete xml content without deleting the content of the object?
    Stamm Level 1
      Hey, with the following code I am marking up a page item and deleting it's xml content:
      text_value = text_area.xmlElements.add('text', current)
      text_value.contents = '';
      current is the current app.selection. The code works, with one downside: It also deletes the content of my text frame in my document. I only want to delete the xml content. Is this somehow possible?
      Thanks in advance!!
      Regards
      Fred
        • 1. Re: How to delete xml content without deleting the content of the object?
          Stamm Level 1
          Does no one have a solution to this? I'm frustrated :/
          • 2. Re: How to delete xml content without deleting the content of the object?
            steverocket2 Level 1
            1. Create a textframe and tag it with an xml Element (e.g. "myTextFrame")
            2. Put some text in the textframe
            3. Select the frame
            4. run the script below
            you added a new xml Element within the tagged frame and changed the content.
            var curSel = app.selection[0];
            var curXMLElement = curSel.associatedXMLElement;
            var newXMLElement = curXMLElement.xmlElements.add('text');
            newXMLElement.contents = "new Content";
            Hope this makes sense.
            Thanks Stefan
            • 3. Re: How to delete xml content without deleting the content of the object?
              Stamm Level 1
              I can't do this. I need to delete the contents of my associated xml element, without deleting the content of the text-frame. I need A) the textframe associated with my xml Element and B) the contents inside the xml tag <text>asd</text> gone, like: <text></text>, without deleting the frame content.
              I did a little workaround now, althought this solution is not really clean.
              I save the contents of the textframe in another variable, delete this content, and then assign the content to the xml attribute where I need it. Of course the user has to close the document without saving then.
              text_value = xmlElements.add('text', current);
              var textContents = text_value.contents;
              var textSize = current.parentStory.characters.item(0).pointSize;
              with(text_value.xmlAttributes){
                  add('value', textContents);
              • 4. Re: How to delete xml content without deleting the content of the object?
                cchimi Level 2
                Your original code works as you describe for me (assuming text_area is set to the Root element).
                • 5. Re: Re: How to delete xml content without deleting the content of the object?
                  Chinnadk Level 4
                  Is this you asking?
                  var doc = app.activeDocument;
                  var text = doc.xmlElements.item(0).evaluateXPathExpression("//text");
                  for(var i =0;i<text.length;i++)
                          text[i].texts.everyItem().remove();
                  Regards,
                  Chinna
                  • 6. Re: How to delete xml content without deleting the content of the object?
                    Adobe-InDesign CS4 Level 1
                    Dear Fred,
                    Please use the below Code, this will helps you to achieve your target.
                    //============================== Script Starts ============================================//
                    var doc = app.documents[0];
                    /* Use Glue Code */
                    __RemoveXMLElments(doc);
                    function __RemoveXMLElments(doc)
                          var elementXpath = "//text";
                            var myRuleSet = new Array (new __RemoveXMLElments_XPath(elementXpath));
                          with(doc){
                            var elements = xmlElements;
                            __processRuleSet(elements.item(0), myRuleSet);
                    function __RemoveXMLElments_XPath (Txts)
                            this.name = "RemoveTexts";
                            this.xpath = Txts;
                            this.apply = function(myElement, myRuleProcessor){
                                with(myElement){
                                    try{
                                            var myCnts = myElement.texts.everyItem();
                                            myCnts.remove();
                                      }catch(e)
                    //============================== Script End============================================//
                    Thanks & Regards
                    T.R.Harihara SudhaN
                    • 7. Re: How to delete xml content without deleting the content of the object?
                      Stamm Level 1
                      Hey,
                      I didn't use xml rules yet, I will look into this topic and come back here as soon as I know more! Thank you for your help!
