This content has been marked as final.
Show 2 replies
1. Re: Why is the audio in my imported video file clipping badly?
Kevin-Monahan Dec 1, 2014 1:37 PM (in response to Hacim00)Hi Hacim00,
Can we get more details on the video file? Check out MediaInfo (free application) for that.
Kevin
2. Re: Why is the audio in my imported video file clipping badly?
Hacim00 Dec 1, 2014 3:21 PM (in response to Kevin-Monahan)Thanks Kevin. Here is the output from MediaInfo
General
Complete name : E:\MAYDAY MPT 2014.rcproject\Movies\1080p.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 873 MiB Duration : 5mn 54s Overall bit rate : 20.7 Mbps Encoded date : UTC 2014-11-30 17:37:40 Tagged date : UTC 2014-12-01 16:58:00 Writing library : Apple QuickTime Video
ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : No Format settings, ReFrames : 2 frames Format settings, GOP : M=2, N=60 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 5mn 54s Bit rate : 20.5 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.330 Stream size : 867 MiB (99%) Language : English Encoded date : UTC 2014-11-30 17:16:37 Tagged date : UTC 2014-11-30 17:37:55 Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Color range : Limited Audio
ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 5mn 50s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 5.25 MiB (1%) Language : English Encoded date : UTC 2014-11-30 17:16:38 Tagged date : UTC 2014-11-30 17:37:55
