4 Replies Latest reply on Dec 8, 2014 9:19 AM by A.T. Romano
    Premiere Elements 13 crashes a lot. And I have only had it for 2 days.
    vickigh Level 1
      Have tried upgrading to 13 from 9 (both photoshop and premiere) but did not have the option.  I am ok with that cause I can go back to 9 for a stable work environment.
      OS windows 7 64 bit home premium with SP-1
      Computer is Intel i7 3.4ghs, 16g ram. multi-terabytes of disk space.
      project is auto selected HDV 1080i
      29.97 fps
      1440x1080
      aspect ratio 1.333
      upper field first
      Audio is 48.000khz sample rate.
      I am actively using NewBlue Cleaner when it crashes.
      Suggestions welcome cause I rather not go back to 9 even though it is still on the machine (32 bit is prob why I could not buy 13 as an upgrade and had to buy full install)
        • 1. Re: Premiere Elements 13 crashes a lot. And I have only had it for 2 days.
          vickigh Level 1
          Additional info on the raw clips.  VLC reports the codec info as follows
          Stream 0
            type: video
            Codec MPEG-1/2 Video (mpgv)
            Language English
            Resolution 1440x1080
            Frame rate 29.970000
            decoded format Planar 4:2:0 YUV
          Stream 1
            Type Audio
            Codec PCM S16 BE (twos)
            Language English
            Channels Stereo
          Sample rate 48000 Hz
            Bits/sample 16
          Hope this helps
          • 2. Re: Premiere Elements 13 crashes a lot. And I have only had it for 2 days.
            A.T. Romano Level 7
            vickigh
            I just saw your thread tonight and had some questions whose answers I hope will lead to resolution for the issues that you described.
            Premiere Elements 13 on Windows 7 64 bit. Am I assuming correctly that this is a purchased product that you are using rather than a tryout?
            What is the brand/model/settings for the camera recorded your source video? How did you get the source media into the project - Add Media/Files and Folders/Project Assets or other?
            1. Do the problems exist with the antivirus and firewall(s) disabled?
            2. Are you using a pen and tablet device instead of a mouse?
            3. Are you running the program from a User Account with Administrative Privileges and have you applied Run As Administrator
            to the desktop icon for the program?
            4. Please confirm with the Device Manager/Display Adapters what your video card/graphics card your computer is using? Are
            there more than 1 card listed there? Is the driver version of the card(s) up to date according to the web site of the manufacturer of
            the card?
            Did you purchase Premiere Elements 13 as a download from Adobe?
            Please confirm - are the crashes so far only when you apply the NewBlue Cleaner Audio Effect?
            Let us start here and then decide what next based on the details that you supply.
            Thank you.
            ATR
            • 3. Re: Re: Premiere Elements 13 crashes a lot. And I have only had it for 2 days.
              vickigh Level 1
              Yes
              Unknown.  It is some type of external video recorder attached to a Sony professional camera. File type is quicktime movie.
              yes
              no
              3. Are you running the program from a User Account with Administrative Privileges and have you applied Run As Administrator to the desktop icon for the program?
              Yes and yes I think.
              4. Please confirm with the Device Manager/Display Adapters what your video card/graphics card your computer is using? Are there more than 1 card listed there? Is the driver version of the card(s) up to date according to the web site of the manufacturer of
              the card?
              NVIDIA GeForce GT 620
              Yes
              It was not when I apply the cleaner audio but when I would move the scrubbing tool to listen to the results.
              The reason I describe this as past tense is that I updated the quicktime on this machine just a few days ago and the program hasn't crashed since.  Apparently it needed the very latest quicktime since I usually update quicktime when it asks.  Since I have not had any crashes since that update  this thread can probably be marked as answered.
              Thanks -Vicki-
              • 4. Re: Re: Premiere Elements 13 crashes a lot. And I have only had it for 2 days.
                A.T. Romano Level 7
                vickigh
                Thanks for the update and the good news that the issue seems to have been resolved by your update of QuickTime.
                If the problem should return (hope not), please let us know and we will revisit the cause and effect.
                Best wishes.
                ATR
