What Do You think of My Feature Requests?
JimmyMcV Dec 1, 2014 1:00 PMHi, I submitted the following Feature Requests to the Premiere CC feature requests form.
I think Premiere CC keeps improving but there are some things that really annoy me. And below are some of my requests. I'd love to know if any of these requests are in error - if I'm actually missing something.
Thanks for checking these out!
*******Enhancement / FMR*********
Brief title for your desired feature:
AUTO-PATCHING
How would you like the feature to work?
When I select a Track Target - such as V1 Target - the Source patch should follow along. For example, if I select V1, then the V1 Source should automatically move next to V1
Why is this feature important to you?
This saves time and saves an extra, unnecessary step of having to move the Source patch.
This makes editing faster and more intuitive.
_________
Increase/Decrease Volume using Keyboard for MULTIPLE CLIPS at once (between In and Out)
1. Set in and out in the Timeline
2. Make sure Audio Targets are set for the tracks you want to affect
3. Press your keyboard shortcuts for increasing or decreasing volume
Result: All Audio volumes between In and Out go up or down by the same amount.
This saves a lot of time. Currently, I have to copy and paste Volume attributes and that wastes time and is not as intuitive.
____
Select Nearest Edit Keyboard Commands Should Select All Nearest Edits on All TARGETED TRACKS, even if staggered
1. Position Playhead near the edits you want selected (for Trim)
1B: Make sure the Track Targets for the tracks you want to affect are highlighted
2. Press the Keyboard Shortcut for Select Nearest Edit…
Result: Even if the edit points don't all line up on the same frame, Premiere should select (with a Roller, etc) ALL edit points NEAREST to the playhead on Tracks which have their Target buttons selected.
How it works now: Now Premiere only select those edit points that line up together the same frame.
How Premiere currently works wastes a lot of time. It currently requires the editor to manually click and add other edit selections.
Currently, Premiere does not actually select all the edit points on SELECTED TRACKS.
_____
REMOVE EFFECT - ALLOW US TO CHOOSE WHICH EFFECTS
1. Highlight one or more Clips to select them.
2. Press the Remove Effects Keyboard Shortcut
What should happen: Premiere should present you with a window that allows you to check the effects you want to remove or uncheck the effects you don't want to remove.
This is very important because often I have a remove just one effect on a large group of effects. I don't have the time - it would take forever - to go through each individual clip and eliminate that particular effect in the Effect Controls panel.
___
A Paste Insert should move the IN/OUT marks down the Timeline, just like the clips
1. Set an In an Out point somewhere in the timeline.
2 In the timeline, after copying some material, PASTE INSERT, the clips in front of a whole bunch of other clips (also earlier than the In/Out marks)
What Should Happen:
Material AND In/Out marks should shift to the right to maintain sync.
What currently happens:
Premiere correctly shifts the Clips that follow the pasted material, Down the Timeline, to maintain sync. However, Premiere keeps the In/Out Marks where they are.
I often copy material that's between In/Out marks and then go earlier in the Timeline and paste Insert that material. But when I jump back to the In point (Go to In) the In/Out marks haven't move and so I have to find my place in the material all over again.
It shouldn't work this way. It wastes time. And other NLEs don't do it this way. They shift the In/Out marks.
