1. Re: Taking forever to send comps to AME CC 2014
Szalam Dec 2, 2014 7:39 AM (in response to deanrockne)Does this happen with every comp regardless of the contents?
As a workaround, try rendering out of AE into an intermediate codec and then using that file in the AME. Any issues with that process?
Does this happen if you work off of and render to your internal hard drive?
2. Re: Taking forever to send comps to AME CC 2014
deanrockne Dec 2, 2014 8:04 AM (in response to Szalam)Hi Szalam, thanks for responding!
As a test I just made a new project with a 720p comp and a single solid with a text layer. It cued up in AME without issues, both saved locally and on the RAID.
I then made a very basic 7000px wide comp and that cued properly as well.
These projects I'm working on that are having issues are fairly complex with lots of footage, AI files, and precomps. Is there any reason that would make it take 10-15min to cue? It doesn't really make sense when saving the project file only takes 2-3 seconds.
I have been rendering to an intermediary in the mean time, it just really slows down my progress since multi-frame rendering hasn't been working in AE. I guess I'll have to dig up my old BG render script.
Thanks for the help!
3. Re: Taking forever to send comps to AME CC 2014
Szalam Dec 2, 2014 8:32 AM (in response to deanrockne)I agree that it doesn't seem like it should be taking as long as it does.
What happens if you import the AE composition from AME instead of sending it to the AME from AE.
Basically, what happens if you pull instead of push?
