6 Replies Latest reply: Dec 6, 2014 11:15 PM by Dov Isaacs RSS
    In Design CS6 - pdf not printing right
    CMCM49 Community Member
      OSX 10.8.5
      Adobe Creative Suite Design Standard / In Design v. 8.0.2  (latest update)
      ISSUE:  Seems to have arisen right after I upgraded my Mac OS from Tiger to Mountain Lion.  Not sure if there's a connection, however.  I just did the latest update for CS6, so don't know if the prior version of InDesign led to the problem either (it was CS6 but I hadn't done an update for awhile).
      Issue:  I created an InDesign page and then generated a press quality PDF for a commercial printer, who put it thru a RIP and then printed it.  My submitted PDF looked just fine, no issues that I could see.  However, on two occasions the pages printed with things missing…..in one case a header at the top and part (not all) of a block of text in the other.  On the second occasion, two bits of text within two separate text blocks were missing.  This NEVER occurred before, ever.  BUT….this has happened since upgrading to Mountain Lion OS and before updating CS6 to the 8.0.2 version I now have.
      My printer said "In Design sometimes doesn't distill a PDF correctly", although this doesn't make sense as I've never had this happen before.  The fonts were fine, not protected, everything was present, all colors were fine, it was just sporadic missing text.  I've looked at everything and can't find any reason for this.
      Has anyone got ideas about this?
        • 1. Re: In Design CS6 - pdf not printing right
          Dov Isaacs Employee Hosts
          Can we assume that you are exporting PDF, not somehow creating PDF via distillation of PostScript? PDF via distillation of PostScript is not reliable.
          And exactly what PDF joboption preset did you use when you exported PDF?
          Quite frankly, I somehow suspect that neither you, the MacOS version, the InDesign version, nor the PDF file itself are the problem.
          The fact that your printer is mumbling about “In Design (sic) sometimes doesn't distill a PDF correctly” leads me to believe that your printer may be the problem. Quite often, printers muck around with perfectly fine PDF files, opening them in (gasp!) Adobe Illustrator “just to check things out and to ‘fix things’.” The problem is that usually there really isn't anything to fix and that Adobe Illustrator is not, repeat not, repeat yet again not a PDF file editor. The only PDF files that Adobe Illustrator can safely open and edit are PDF files saved from Adobe Illustrator if and only if the “save editability” option is selected when such a PDF file is saved. Otherwise, it is very possible that text and other PDF objects may be lost or otherwise modified, colors changed, etc. The damage occurs when the PDF file is opened in Illustrator and becomes permanent when such a file is saved, even if nothing is explicitly done to the file by the user!
          Alternatively, your printer may have a wonky PDF workflow system with very out-of-date components or a very, very out-of-date RIP/DFE.
          Generally speaking, if you can open the PDF file in Acrobat or Adobe Reader and print successfully to a local print device, you should have no problems of the type you describe.
                    - Dov
          • 2. Re: In Design CS6 - pdf not printing right
            I appreciate the quick reply!  I am creating an In Design file, then exporting to PDF using the press quality setting.  I haven't had this problem of disappearing text in 5 years with this printer, so that's 60 magazine issues without a problem.  I just talked to the pre-press guy, and they haven't changed their RIP or anything, nothing has changed with them.  They never mess with my PDF files, either so they aren't doing anything to it.
            We talked about my work habits, and this is one POSSIBLE problem….I copy a page over and over….so I'll take last month's ad page, duplicate the whole file and re-name it for the next issue, and make changes on the new copy.  He thought perhaps over doing this multiple times some unseen "damage" to the In Design file may have occurred.  He suggested I create a new file to work from since the two files I had a problem with have been copied as I described at least 20 times each, maybe more.
            I have Adobe Acrobat X version 10.1.10.   Should I open the In Design created PDF into Acrobat X to "check" it out, or is that necessary?
            • 3. Re: In Design CS6 - pdf not printing right
              The more theories I hear espoused by your “printer,” the less respect I have for him. He is grabbing at straws, and not even any good straws at that!
              I have reused content in the manner that you describe for many years over many “new” InDesign documents without any such problems.
              If you can simply open a PDF file exported from InDesign in Adobe Reader or Acrobat, see all the content, and print it successfully to a cheap office printer, then the PDF file should be “good to go” for professional printing, at least in terms of rendering text properly.
              Thinking about this some more, the only areas where things could start getting wonky is if you are using strange combinations of transparency, overprinting, and spot colors in the areas where the text “disappears.” If you have a sample PDF file that you can share, we can analyze whether indeed there is anything non-kosher about it or whether your “printer” is in fact corrupting your work.
                        - Dov
              • 4. Re: In Design CS6 - pdf not printing right
                How can I get the actual "problem" PDF to you?  The email's I've received from this board are "no reply" type emails.
                • 5. Re: In Design CS6 - pdf not printing right
                  Steve Werner CommunityMVP
                  You can post the file on a cloud service like Dropbox, and provide a link to the file.
                  • 6. Re: In Design CS6 - pdf not printing right
                    You can send a private message to me on the forums with a pointer to the file after receiving such an e-mail, I can give you my e-mail such you can send the file (if less than 50MB) via e-mail.
                              - Dov
