This content has been marked as final.
Show 1 reply
1. Re: Acrobat Pro XI - How to Modify Existing Alt Text?
a C student Dec 1, 2014 9:23 PM (in response to Data Daddy)Hi Pete,
One way to edit alt text is in the Tags pane. Along the left of the screen you may see an icon that looks like a tag. Mouse over text will read "Tags: View and edit structured PDF information". If it is not there then View > Show/Hide > Navigation Panes > Tags. Once you open the Tags pane, locate the Figure tag with inaccurate alt text, right click it and select Properties. Alt text is on the Tags tab of the Object Properties dialog, and should be displayed by default.
Another way is to select the Touch Up Reading Order tool, then right-click the image and select "Edit Alternate Text".
Hope this helps.
a "C' student
