1. Re: Premiere CC 2014 Won't Play
Joshua Sims Dec 1, 2014 8:13 PM (in response to Joshua Sims)And for the record, I can't find another Post for this question.
2. Re: Premiere CC 2014 Won't Play
R Neil Haugen Dec 1, 2014 9:58 PM (in response to Joshua Sims)One of the first things to try (as it's quick & simple and sometimes fixes the problem) is to quit PrPro, then while holding down opt & shift (I think ... might be alt-shift) start up PrPro again. This forces PrPro to start up WITHOUT referencing the current "preferences" file, and if it starts & work right, you had a corrupt pref's file. And you're good to go. Past that ... check back in. And actually, there have been other threads with this problem, but if you don't search by the EXACT words used in the title or any category tags the OP of the other thread used, this search will NOT look around creatively.
Some people go out & in a different tab of their browser use Google to search for the problem. To find an answer here ...
Neil
3. Re: Premiere CC 2014 Won't Play
RameezKhan Dec 2, 2014 12:11 AM (in response to Joshua Sims)Hi Joshua,
Neil has pointed you in the right direction. However, if that doesn't help please provide the following information.
Have you connected any external audio device such as a headphone or a mic or anything else?
Does this happen with all the projects or just one?
Rameez
4. Re: Premiere CC 2014 Won't Play
Joshua Sims Dec 2, 2014 5:22 AM (in response to RameezKhan)I resent with out permissions, with no change.
I unplugged the external audio device, nothing smart or hardware related, just a 2.1 stereo jack speaker kit. No change there either.
It happens with all projects. It's happened since I updated to the most current about 3 days ago.
5. Re: Premiere CC 2014 Won't Play
RameezKhan Dec 2, 2014 7:45 AM (in response to Joshua Sims)Go to Audio Hardware under Preferences and change the Adobe Desktop Audio settings one by one and see if that helps.
Rameez
6. Re: Premiere CC 2014 Won't Play
Velorescobareaolapdance Dec 2, 2014 7:54 AM (in response to Joshua Sims)I am experiencing the exact same issue. I just installed Premiere yesterday. Nothing will play in any of the windows. I press the play button and it turns to a square, then nothing.
Looks like I am staying with FCP untill a solution is available. I have an iMac with 3.4 GHz i7 and 32 gb of RAM.
7. Re: Premiere CC 2014 Won't Play
RameezKhan Dec 2, 2014 8:00 AM (in response to Velorescobareaolapdance)Please follow the two steps that are mentioned in the posts above and see if it works.
Rameez
