1. Re: Black lines not all showing up the same color when exported as any type file
sishamDSS Dec 2, 2014 1:26 AM (in response to mlarts)Can you please highlight the specific lines that you are talking about? I have looked at the image and there seems to be a lot of different colours on the lines, looks like some may be overlaid or something?
3. Re: Black lines not all showing up the same color when exported as any type file
Monika Gause Dec 2, 2014 2:04 AM (in response to mlarts)Please select them in Illustrator and show screenshots with selection and color values.
4. Re: Black lines not all showing up the same color when exported as any type file
mlarts Dec 2, 2014 2:11 AM (in response to Monika Gause)I've figured it out sort of. When I export in RGB the lines show up even in color. When I export in CYMK the lines show up different in color. If I am using this file for business cards and I upload in RGB will it print evenly?
5. Re: Black lines not all showing up the same color when exported as any type file
sishamDSS Dec 2, 2014 2:22 AM (in response to mlarts)If you are printing business cards you are best having a CMYK version that is correct in colour. If you print from RGB the colours will all come out incorrect (will look faded compared to the on-screen version).
Are you able to select just the outlines, duplicate them and bring them to front? It is difficult to know what to suggest without seeing how the file is built, can you select outlines as Monika suggested and send a shot of that .
6. Re: Black lines not all showing up the same color when exported as any type file
mlarts Dec 2, 2014 2:44 AM (in response to sishamDSS)Unfortunately my file is set up like a hot mess. Everything is in the same layer and I should have definitely done multiple ones. This is only the second logo I've designed and I'm learning as I go. Basically I did an image trace of the drawing and then went back and manually fixed lines. Instead of having only a few to select I have many all in the same layer as my color.
I noticed my vector logo works fine when exported. It's the files where I am resizing it that are coming up in the different colors.
7. Re: Black lines not all showing up the same color when exported as any type file
mlarts Dec 2, 2014 3:11 AM (in response to mlarts)Thanks for the help everyone. I went into the resized files and used live paint to recolor the lines and Overprint Preview to see the trouble spots in Illustrator. Still not sure what happened in the first place.
