3 Replies Latest reply: Dec 2, 2014 9:33 AM by ryclark RSS
    Speech Volume Leveler Latency?
    xSonic521x Community Member
      I'm a soft spoken person so I was looking for an option to have my voice at a constant volume no matter how soft and loud it may be. Other reasons I chose that feature was to avoid clipping and other problems that my mic and environment cause me. Though the problem is quite a bit of latency when I choose to monitor it. Only few effects give me such a delay so I was wondering if this is normal or not. Also, the reason I am monitoring it is because I actually am using it to help with mic issues and well, my own vocal issues for live streaming games and such.
        • 1. Re: Speech Volume Leveler Latency?
          ryclark Community Member
          You would be much better off using a Compressor from the Amplitude and Compression Effects menu. These are meant for voice recording and should have a much lower latency. The Speech Volume Leveler effect is really meant for post production use on a ready recorded audio file rather than on a live input.
          Try the Voice Leveler or Voice Over presets in the Single Band Compressor or the Tube Modelled Compressor.
          • 2. Re: Speech Volume Leveler Latency?
            Unfortunately those presets have the Speech Volume Leveler as part of them. Is there any other effects, whether it be just one or multiple to give a constant level of input regardless of said input volume? You mentioned a seperate Voice Leveler effect right? I think I found it, it should give the same results right? The other added benefit that I did like with the Speech Volume Leveler was that I could set it so that clipping never happens regardless of how loud I scream aside from the fact that it boosted and/or lowered my voice to a constant volume, are there any other effects that do this as well?
            • 3. Re: Speech Volume Leveler Latency?
              No, the Voice Leveler presets in the two mentioned Compressors are completely different from the Speech Volume Leveler effect. You would also need one of the Limiter effects to help stop your voice clipping but this won't protect the audio completely as the maximum level depends on the settings for your mic preamp and how you use the mic.
              But in order to use these tools you will need to understand a bit more about what they do. So Take a look at this video on Improving Voice overs.
              Improving Voice Over Quality in Adobe Audition - YouTube
