Acrobat v.7 settings saved but not applied
David.G.P Dec 1, 2014 11:57 PMI have the exact same problem as in below discussion -- except that it is not Acrobat 8 but Acrobat 7.
Why my acrobat settings can not be saved?
There is full registry access for Administrator and System to the Acrobat registry settings under
HKEY_CURRENT_USER\Software\Adobe\Adobe Acrobat\7.0
If I change certain settings, for example under "General" -> "Use Single Key Accelerators To Access Tools", this DOES get saved to the registry.
Still however, Acrobat does not seem to read this setting from the registry. However, it writes AND reads other settings perfectly well, like for example "General" -> "Make Hand Tool Select Text".
What could be the reason for this behaviour?
David.P
Diese Frage ist Unbeantwortet
ChromeUser 07.07.2009 20:18
I'm using acrobat pro 8.1.5 on windows xp + sp2.
This problem disturb me for a long time.
I remember that acrobat could save the toolbar positon before.
But now it can not.
My acrobat always show "Task", "Select & Zoom", "Page Navigation", "Page Display", "Find", "File" these six toolbars when it start up.
Although i disabled these toolbars but they will show again next starting up.
I don't know why,how can i resolve this problem?
Thanks.
1. Re: Why my acrobat settings can not be saved?
I have no problem with Adobe Acrobat 8.1.6.
2. Re: Why my acrobat settings can not be saved?
I have updated my acrobat to 8.1.6,but it just like before, no change.Anyone can help me
Thanks.
3. Re: Why my acrobat settings can not be saved?
It seems to be due to the registry access issue by adrobat.If you're using Vista, have you tried running Acrobat using "Run as Admin" ?!
4. Re: Why my acrobat settings can not be saved?
Yes,I also think that due to the registry access issue by adrobat.But i could not found why it access registry error.
Im running as Admin and my OS is WinXP + SP2
5. Re: Why my acrobat settings can not be saved?
You can check the registry access rights of these registry keys using windows Regedit tool
HKEY_CURRENT_USER\Software\Adobe\Acrobat\9.0or
HKEY_CURRENT_USER\Software\Adobe\Acrobat\9.0\AVGeneral\cToolbars
6. Re: Why my acrobat settings can not be saved?
This is the registry after i disable taskbar and close acrobat.[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral]
"bLastExitNormal"=dword:00000001
"bActivated"=dword:00000001
"bAppInitialized"=dword:00000001
"bForceQuitApp"=dword:00000000
"bInTrialMode"=dword:00000000[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\cdockables]
[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\cdockables\cpdfstandards]
[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\crecentfiles]
[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\crecentfiles\c1]
"sDI"=hex:2f,48,2f,54,65,73,74,44,61,74,61,2f,32,30,30,39,2f,30,36,2f,50,4b,43,\
53,31,2e,70,64,66,00
"tDIText"="/H/TestData/2009/06/PKCS1.pdf"
"aFS"="DOS"[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\ctoolbars]
[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\ctoolbars\cadvcommenting]
[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\ctoolbars\cbasiccommenting]
[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\ctoolbars\ccommenting]
[HKEY_CURRENT_USER\Software\adobe\adobe acrobat\9.0\avgeneral\ctoolbars\ccommenting\cstamp]
"bInternalExpanded"=dword:00000001I thinks taskbars setting should be show here,right?
7. Re: Why my acrobat settings can not be saved?
Did you check the registry access rights of the registry keys?
8. Re: Why my acrobat settings can not be saved?
Sorry,I don't know how to check the registry access rights of the registry keys.Can you tell me?
9. Re: Why my acrobat settings can not be saved?
In the regedit tool select the key and use the menu edit.
10. Re: Why my acrobat settings can not be saved?
Yes, i have the full control to these keys.
