This content has been marked as final.
Show 3 replies
1. Re: Comment superposer plusieurs photos traitées avec des calques?
Silkrooster Dec 2, 2014 9:37 PM (in response to opato78)When you place a psd file, it should load as a smart object. You can scale these all you want with out affecting the underlying image.
Another solution is to select all the layers of an image then convert to a smart object. Now you can drag and drop into another document.
Another solution is to create a composite, select all the layers then press ctrl-alt-shift-e (windows) cmd-opt-shift-e (mac) then hide the lower layers or drag and drop the composite to a new document.
2. Re: Comment superposer plusieurs photos traitées avec des calques?
opato78 Dec 3, 2014 9:20 AM (in response to Silkrooster)Thank you Silkrooster
3. Re: Comment superposer plusieurs photos traitées avec des calques?
Silkrooster Dec 3, 2014 9:11 PM (in response to opato78)You're welcome.
