This content has been marked as final.
Show 7 replies
1. Re: problem with transparency while exporting pdf with linked psd files into interactive pdf
Willi Adelberger Dec 2, 2014 3:34 AM (in response to wdewuidfcehw)With which program are you openening the result?
2. Re: problem with transparency while exporting pdf with linked psd files into interactive pdf
wdewuidfcehw Dec 2, 2014 4:09 AM (in response to Willi Adelberger)adobe acrobat
3. Re: problem with transparency while exporting pdf with linked psd files into interactive pdf
Willi Adelberger Dec 2, 2014 4:19 AM (in response to wdewuidfcehw)What is the Transparenc Flattening Color space? RGB?
4. Re: problem with transparency while exporting pdf with linked psd files into interactive pdf
rob day Dec 2, 2014 4:47 AM (in response to wdewuidfcehw)Are you making the drop shadow in InDesign? Is the drop shadow color CMYK or RGB? If it's the default CMYK [Black] try using an RGB black and adjusting the opacity.
6. Re: problem with transparency while exporting pdf with linked psd files into interactive pdf
wdewuidfcehw Dec 2, 2014 6:32 AM (in response to rob day)drop shadows are made in photoshop, color everywhere is RGB
7. Re: problem with transparency while exporting pdf with linked psd files into interactive pdf
Jeffrey_Smith Dec 2, 2014 6:57 AM (in response to wdewuidfcehw)Are there any drop shadows created in Indesign? I can recreate your issue with 1 Photoshop image with shadow along with an Indesign object applied a CMYK black shadow. In this case, the imported image with shadow is darker. If I change the Indesign object's shadow to RGB black (as Rob mentions), then both shadows appear correctly.
