1. Re: Not able to create book using structured framemaker
mattrsullivan Dec 2, 2014 4:57 PM (in response to kirankatekar24)Are you having difficulty mapping your Fm content to Rh?
Rh needs paragraph styles to map content from Fm, even when it's structured Fm.
To make use of the content mapping, you'll need to assign a paragraph style in your EDD, even if the paragraph style doesn't actually do anything to the formatting (you can leave everything set to As is)
After that, you can map your content into Rh as you would expect.
-Matt
2. Re: Not able to create book using structured framemaker
kirankatekar24 Dec 2, 2014 11:16 PM (in response to mattrsullivan)Yes, I have all formatting is done.
Provided all heading levels
Heading1
Heading 2 and so on.
Followed following steps:
1. We author in structured framemaker
2. Open Robohelp and import structured framemaker files
3. Conversion settings >>FrameMAker Setting>> Paragraph >> Heading 1 >> select Pagination (split into topics based on this style >> OK
4. Select ToC FM >> OK
Only chapter level books are getting generated but not Heading level.
