1 Reply Latest reply: Dec 2, 2014 8:43 AM by rezun8 RSS
    AS3 + Clicktag/doubleclick for noob
    as3 and clicktag issue Community Member
      It's been about 10 years since I've had to build anything in Flash, and I'm feeling like a complete noob, hoping someone can help.
      I've created my flash ad, and unfortunately did so in AS3.  I need to add a ClickTag for doubleclick ad serving.  I've created a new layer with a 0% alpha rectanger, converted to a button, and named "btnClickTag".  I've also turned on linkage, and given it a class of "btnClickTag".  I also added a keyframe to the end of my timeframe so the layer extends the whole animation (not sure if this is needed).  After hitting multiple 1120 errors, and reading through forums I've come up with the following actionscript:
      import flash.events.MouseEvent;
      import flash.net.URLRequest;
      import flash.net.navigateToURL;
      btnClickTag.addEventListener(MouseEvent.CLICK, tagClick);function tagClick(event:MouseEvent):void{navigateToURL(new URLRequest( root.loaderInfo.parameters.clickTAG), "_blank");}
      I am now getting the following error, and can't seem to find a solution.  I'm not an engineer so I'm sure I'm mising something simple.  I've also uploaded into doubleclick and can see the clicktag not working properly.
      Scene 1, Layer 'clicktag', Frame 1, Line 5, Column 131061: Call to a possibly undefined method addEventListener through a reference with static type Class.
      Thanks!
      G
