2 Replies Latest reply: Dec 3, 2014 3:47 AM by SharpyUK RSS
    Premier Elements 13 Audio cut-out when importing an MP4 movie. Audio plays fine in VLC and WMP.
    SharpyUK Community Member
      Hi Guys.
      Just brought PE13 but I'm having problems editing some PlayStation4 footage. The file is an MP4.
      The clip plays fine in VLC and WMP with all audio intact. However, when I import it to PE13, the audio cuts out.
      As seen in the audio timeline, the audio cuts out. This is around 30 seconds.
      I've tried re-transferring the files from the PS4 to my PC but to no avail.
      Any Ideas?
      Sharpy.
        • 1. Re: Premier Elements 13 Audio cut-out when importing an MP4 movie. Audio plays fine in VLC and WMP.
          A.T. Romano Community Member
          SharpyUK
          I am guessing that it is the audio mp4a files that are at the core of the matter.
          Is your video and audio linked at import or do you have them existing on the Timeline unlinked.
          You could try
          Exporting only the audio portion of the file to mp3 or wav and then re-importing the mp3 or wav into the
          project, determining if you have sound and in sync with the whole video.
          Publish+Share
          Computer
          Audio
          Presets = one for .mp3 or .wav
          and under the Advanced Button/ of the preset selected set for Export Audio only.
          ATR
          • 2. Re: Premier Elements 13 Audio cut-out when importing an MP4 movie. Audio plays fine in VLC and WMP.
            Hi there.
            I have tried exporting audio only but it again cuts out at around 30 seconds. I have noticed on some other clips that the audio will play fine in VLC but will cut out at random times when imported into PE13. Do you know of a way that I could seperate audio and video and join them together once they're both imported? Perhaps there is a way to convert the MP4a audio to a different codec?
            I must admit, I have a basic knowledge of video editing but I've not come across this problem before. I also tried importing the same clip into Windows Movie Maker (I know, it sucks.) and was presented with an incompatibility error.
            SharpyUK
