1. Re: Phantom lines appearing
deepakgahlot Dec 2, 2014 10:30 AM (in response to dan stack)Hi,
could you also provide what kind of the system are you using, is it MAC OR Windows.
2. Re: Phantom lines appearing
dan stack Dec 2, 2014 11:05 AM (in response to deepakgahlot)Photoshop 2014.1.0 / 20140730.r.148 x64
OSX 10.9.2
2.66 Quad Xeon
12GB 1066MHz DDR3
ATI Radeon HD 4870 512 MB
3. Re: Phantom lines appearing
deepakgahlot Dec 2, 2014 11:20 AM (in response to dan stack)Hi
can you go to the Adobe Photoshop Preferences > performance
please click on the advance setting under Graphics Processor setting
Please change the Drawing mode to basic, if it is already on the Basic then change it to advance
restart the Photoshop and try the same
4. Re: Phantom lines appearing
dan stack Dec 2, 2014 12:36 PM (in response to deepakgahlot)Thanks deepakgahlot, neither drawing mode nor "Use Graphics Processor" on/off make any difference.
Having said that, I fixed it. It was apparently some sort of artifact from the layer mask around the bird illustration. When I extended the mask to the full frame the lines went away. It is definitely an artifact and not part of the image being masked since there isn't any black under the mask in that area. I'd still like to know why PS is rendering the edges of the mask, but the workaround seems to have solved it.
Thanks for your suggestions.
