1 Reply Latest reply on Dec 2, 2014 2:54 PM by A.T. Romano
    Premiere Elements 13 Video Cross-Fade
    Namreteid
      Hey everybody!
      I´ve got a problem with the video cross-fade. For example the Dissolve.
      I put the Dissolve as an cross-fade between two Clips and I want that while the cross-fade both Clips are running. But the second Clip only starts when the first clip stopped.
      So does anybody how I can configure that while the cross-fade both clips are running?
      Hope that anybody can help me :-)
        • 1. Re: Premiere Elements 13 Video Cross-Fade
          A.T. Romano Level 7
          namreteld
          What are you setting for the alignment (Left Clip, Between Clips, or Right Clip) of the Cross Dissolve and what are you setting as the transition duration?
          If you have not already, please consider Between Clips as the alignment setting and increase the transition from 1 to 2 seconds.
          Does that make a difference with regard for what you seek?
          Also, we might have to get into the topic of trimmed and untrimmed clips.
          Please review and consider and then we can discuss this further.
          Thank you.
          ATR
          Add On....Have you worked with other versions of Premiere Elements and are only finding this problem now in 13?
