9 Replies Latest reply on Dec 3, 2014 3:57 PM by Choral Creations
    Export to PDF
    kirito69
      Can't export any files to pdf! ANY!
        • 1. Re: Export to PDF
          Version of ID, OS?
          What happens when you try?
          • 2. Re: Export to PDF
            kirito69 Level 1
            indesign cc, yosemite.
            couple of seconds it's run background task and then failure to export to pdf. the same file can be easily exported to pdf in windows but not on mac. and then I can't even open the indd file and I have to redo everithing!
            • 3. Re: Export to PDF
              Any error message? Are you sure yo have permission to write to the folder where you are trying to save the PDF? Can you export it to the Desktop?
              How about other files? Do they export?  Does this one work if you log onto the Mac in a different user?
              • 4. Re: Export to PDF
                What settings do you use?
                What is the content of your file?
                • 5. Re: Export to PDF
                  Choral Creations
                  I have the same problem. I cannot print to an external PDF creation device such as an Adobe PDF print driver, Primo PDF, PDF Creator, etc. I also cannot export an InDesign file into PDF format. When trying to print to the Adobe PDF print driver, the software hangs with "Downloading procset." When I try to export to a PDF file, InDesign looks as if it is creating the PDF file, but it never shows up.
                  Adobe CS3
                  Computer
                  Model : HP Z600 Workstation
                  Serial Number :
                  Chassis : HP Mini Tower
                  Mainboard : HP 0AE8h
                  Serial Number :
                  BIOS : HP 786G4 v03.54 11/02/2011
                  NUMA Support : 2 Unit(s)
                  Total Memory : 24GB ECC DIMM DDR3
                  Processors
                  Processor : Intel(R) Xeon(R) CPU           E5520  @ 2.27GHz (4C 2.4GHz/2.53GHz, 2.13GHz IMC, 4x 256kB L2, 8MB L3)
                  Socket/Slot : FC LGA1366
                  Chipset
                  Memory Controller : HP 5520 (Tylersburg-36D) I/O Hub 2x 2.93GHz (5.85GHz)
                  Memory Controller : HP Xeon (Nehalem) UnCore 2x 2.93GHz (5.85GHz), 3x 4GB ECC DIMM DDR3 1GHz 192-bit
                  Memory Module(s)
                  Memory Module : Freescale (Motorola) 18KSF51272AZ-1G6K1 4GB DIMM DDR3 PC3-12800U DDR3-1600
                  Video System
                  Monitor/Panel : Samsung S24B150
                        (1920x1080, 29.8")
                  Video Adapter : ASUS R9 270X Series (20CU 1280SP SM5.0 1.12GHz, 4GB DDR5 5.6GHz 384-bit, PCIe 3.00 x16)
                  Graphics Processor
                  OpenCL GP Processor : ASUS R9 270X Series (1280SP 20C 1.12GHz, 3GB DDR5 5.6GHz 256-bit)
                  Compute Shader Processor : ASUS R9 270X Series (1280SP 20C 1.12GHz, 4GB DDR5 5.6GHz 384-bit)
                  Storage Devices
                  GB0750C4414 (750.2GB, SATA150, 16MB Cache) : 699GB (C:)
                  WDC WD2002FAEX-007BA0 (2TB, SATA300/600, 3.5", 7200rpm) : 2TB (E:) (F:) (G:) (H:)
                  WDC WD2002FAEX-007BA0 (2TB, SATA300/600, 3.5", 7200rpm) : 2TB (D:) (I:)
                  ASUS    BW-16D1HT (SATA150, BD-RE, DVD+-RW, CD-RW, 4MB Cache) : N/A (Z:)
                  Logical Storage Devices
                  Peripherals
                  LPC Hub Controller 1 : HP LPC Interface Controller
                  LPC Legacy Controller 1 : SMSC SCH5317-B
                  Audio Device : ASUS CMI8788 [Oxygen HD Audio]
                  Audio Device : ASUS Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
                  Audio Codec : ATI (AMD) HDMI Audio
                  Serial Port(s) : 2
                  Disk Controller : HP ICH8R (ICH8) SATA RAID Controller
                  USB Controller 1 : HP USB UHCI Controller #4
                  USB Controller 2 : HP USB UHCI Controller #5
                  USB Controller 3 : HP USB UHCI Controller #6
                  USB Controller 4 : HP USB EHCI Controller #2
                  USB Controller 5 : HP USB UHCI Controller #1
                  USB Controller 6 : HP USB UHCI Controller #2
                  USB Controller 7 : HP USB UHCI Controller #3
                  USB Controller 8 : HP USB EHCI Controller #1
                  SMBus/i2c Controller 1 : Intel ICH SMBus
                  Printers and Faxes
                  Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour)
                  Printer : PDFCreator (4000x4000, Colour)
                  Printer : HP LJ300-400 color M351-M451 PCL 6 (600x600, Colour)
                  Printer : Microsoft XPS Document Writer (600x600, Colour)
                  Printer : HP LJ300-400 color M351-M451 PCL 6 (600x600, Colour, Duplex)
                  Fax : Microsoft Shared Fax Driver (200x200)
                  Printer : Adobe PDF Converter (4000x4000, Colour)
                  Network Services
                  Network Adapter : Broadcom NetXtreme Gigabit Ethernet #3 (Ethernet)
                  Wireless Adapter : ASUS PCE-N53 300Mbps 11n Dual band Wireless LAN PCI-E Card (802.11n (HT), AES-CCMP, 150Mbps)
                  Operating System
                  Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
                  Platform Compliance : x64
                  Windows Experience Index
                  Current System : 5.8
                  Bob
                  • 6. Re: Export to PDF
                    Don't use print to create PDF, use export to PDF.
                    • 7. Re: Export to PDF
                      Choral Creations Level 1
                      I SAY AGAIN:  "When I try to export to a PDF file, InDesign looks as if it is creating the PDF file, but it never shows up."
                      In other words, I've already tried to export to a PDF file inside of InDesign.
                      Bob
                      • 8. Re: Export to PDF
                        What are your settings?
                        What is the content of your document?
                        • 9. Re: Export to PDF
                          Settings of what? there are a host of OS and Adobe settings that could have an impact. To which set of settings are you referring?
                          Text only. Well, almost text only. There are some horizontal lines. All of the fonts are active and properly linked to the document.
                          Here's a sample page:
