• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Memory leak/overload when looping by index over a large query and updating each DB record
New Here ,
Dec 03, 2014 Dec 03, 2014
I am importing a CSV file into a temporary table and then running a select query that joins my actual database table with the temporary table, looking for any changes in the data. If changes exist, the select query is looped from 1 to #recordCount# and an update is applied to each record via cfquery. It runs very quickly (much more quickly than looping the query itself), but my memory spikes and overloads after about 1500 updates are completed. I need to be able to do upwards of 20000 at a time, without killing my system. I have tried manually setting the runtime garbage collection to trigger after X number of loops, but that doesn't seem to help. I am running CF8. See below for loop example:
<cfloop from="1" to="#updatedRecordsQuery.recordCount#" index="a">
<cftry>
                <cfquery datasource="#db#" name="doUpdate">
                    UPDATE
                        CI
                    SET
                        firstname = <cfqueryparam cfsqltype="cf_sql_varchar" value="#updatedRecordsQuery.firstname#" />,
                        lastname = <cfqueryparam cfsqltype="cf_sql_varchar" value="#updatedRecordsQuery.lastname#" />,
                        etc, for about 15 various fields
                    FROM
                        client_info CI
                    WHERE
                        CI.client_id = <cfqueryparam cfsqltype="cf_sql_integer" value="#updatedRecordsQuery.client_id#" />
                </cfquery>
                <cfcatch type="database">
                    <cfset local.updateErrorList = listappend(local.updateErrorList,updatedRecordsQuery.client_id) />
                    <cfset local.error = true />
                </cfcatch>
           </cftry>
</cfloop>
Views
414
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide ,
You can simplify your code a bit by looping over the updatedRecordsQuery directly, instead of doing an index loop:
<cfloop query="updatedRecordsQuery">
Then inside your loop, you don't need the loop index references at all, so "updatedRecordsQuery.firstname" becomes "updatedRecordsQuery.firstname".
That probably won't address your performance issue though.  Looping that many records is going to be resource intensive.  Since you are already storing the new data in a temporary table on the database server, it seems like you could try to offload the process of updating your "CI" table to your database server as well.  Maybe you can write a stored procedure that you can call from CF using <cfstoredproc> or <cfquery>.  What DBMS are you using?
-Carl V.
Votes
Translate
Translate
Report
Report
Participant ,
Dec 08, 2014 Dec 08, 2014
I would suggest to use select update instead of looping over query object and update each row one-by-one.
Procedure:
- Insert your CSV data into temp table.
- Use a select update SQL query to update the changed data instead of looping over a select query.
Example:
UPDATE
Table
SET
Table.col1 = other_table.col1,
Table.col2 = other_table.col2
FROM
Table
INNER JOIN
  other_table
ON
Table.id = other_table.id
NOTE: You can put all your scripts in a Procedure.
Votes
Translate
Translate
Report
Report
Participant ,
Dec 09, 2014 Dec 09, 2014
LATEST
Maybe this is a dumb question but how are you detecting updated rows in the temp table.
Is there a "update date" field that indicates a change or are you scanning/comparing multiple fields.
If the answer is the second option maybe you can add a date stamp to the application that creates the csv file and add a date variable to your temp table query WHERE statement.
Votes
Translate
Translate
Report
Report
Resources
Documentation
