3 Replies Latest reply on Mar 11, 2016 1:42 AM by Anit_Kumar
    Coldfusion 10 ODBC Services
    dboiler
      I have a server with an installation of ColdFusion 10 however the ODBC Services did not get installed with the initial installation. Is there a simple, manual method for installing ODBC Services without uninstalling CF and then reinstalling with that option selected? I have tried running the installation over the current one but with the Configure Installer window, it has Server Configuration greyed out as it has found a current installation. It then gives an option of either EAR file or WAR file in the JEE configuration. Not sure which to choose so that's why I ask the question of a manual install.
      Thanks in advance. This is running on a Windows Server 2008 R2 64-bit box.
      Dave
        • 1. Re: Coldfusion 10 ODBC Services
          Anit_Kumar Adobe Employee
          Here is the script to install ODBC services
          <cfscript>
            //login using admin
            //createObject("component","cfide.adminapi.administrator").login("administrator_password" );
            createObject("component","cfide.adminapi.administrator").login("admin");
            //instantiate datasource object
            myObj = createObject("component","cfide.adminapi.datasource");
          </cfscript>
          To Install ODBC Services:
          <cfscript>
                   writeOutput("Installing ODBC Services...<br>");
                   returnValue = myObj.installODBCservice();
                   writeOutput("ODBC Services installed");
          </cfscript>
          Regards,
          Anit Kumar
          • 2. Re: Coldfusion 10 ODBC Services
            dboiler Level 1
            This issue has resurfaced. I try to run this script but all I get is a screen with a large blue circle with the word Error inside it.
            Any advice?
            Dave
            • 3. Re: Coldfusion 10 ODBC Services
              Can you try to uninstall the corrupt service first, by using the below code.
              <cfscript>
                //login using admin
              </cfscript>
              NOW TO REMOVE ODBC SERVICES:
              <cfscript>
                   writeOutput("Removing ODBC Services...<br>");
                   returnValue = myObj.removeODBCservice();
                   writeOutput("ODBC Services removed");
              </cfscript>
              Delete all the .trc files available at \cfusion\db\slserver54\tracing\ .
              And then install using the below code.
              <cfscript>
                //login using admin
              </cfscript>
              <cfscript>
              </cfscript>
              Regards,
              Anit Kumar
