8 Replies Latest reply on Dec 8, 2014 2:36 PM by Rebecca.Navarrete
    The quality of the footage is lost when I use certain settings in Premiere Pro CS6
    Rebecca.Navarrete
      Hello ,
         I filmed footage on a Canon XA10. They are MTS files and the codecs are 1440x 1080, frame rate 29.97, H264- MPEG- 4AVC, input nitrate 9854, and stream nitrate is 8971
      I need to submit them as application samples for a job. The job requires certain settings to be used.
      for HD 1080i  the application sample should be 960 x 540 @ 29.97
      they have other settings, like NTSC should be 320 x 243 @ 29.97
      With one file I filmed rain and in the original file it's clear and the quality it really good. I export using the settings H.264 and Apple TV, iPad, iPhone 4 or newer - 960 x 540 29.97
      under basic video settings is
          width 960
          height 540
      frame rate 29.97
      After exporting it the .mp4 file came out pixelated and the image quality is much lower.
      I had another problem with a file shot with the same camera and the same codecs  (MTS files and the codecs are 1440x 1080, frame rate 29.97 ect.)
      It was footage that I had to speed up, after exporting it came out shaky. When I export with the 1440 x 1080 settings it's not shaky, but I need it to be 960 x 540. I can't turn in shaky footage.
      What am I doing wrong and how can I get footage that is acceptable for submission?
