• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Air 16 (222) for Ios 8 Geolocation Mute and no asking permission
New Here ,
Dec 04, 2014 Dec 04, 2014
Hi all,
my app never ask for Geolocation permission and it always gave me Geolocation mute.
I've already try the app.xml changes (<name><text xml:lang='en'>MyAppName</text></name>),
adding and removing UIrequiredDeviceCabalities, but no way to make it works...
I have this issue with also Air 15(last) and 16(214)
Someone with the same issue?
TOPICS
Performance issues
Views
1.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner ,
Jan 05, 2015 Jan 05, 2015
This is due to changes in iOS8 that require additional permissions to be requested before you are able to access location services.
At this stage you'll need to use an ANE to be able to achieve this, I think.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 07, 2015 Jan 07, 2015
Yeah i'm already work on it...
but i can't understand why Adobe don't beta test his releases or why they correct it on Phone Gap and not on Air...
Adobe do you have in mind to solve this? Or you think that, once you add Native Extensions, we have to keep to check and correct every new release by ourself?
Votes
Translate
Translate
Report
Report
If you're interested, we have just added support to our NativeMaps ANE to allow this functionality. We're going to be releasing a Location ANE soon as well which will be cheaper and also contain support for allowing the location authorisation. (distriqt // air native extensions)
Votes
Translate
Translate
Report
Report
New Here ,
Good to know, because i'm already one of your clients!
I have the old version of Ane Master Pack, is that update included or i need to upgrade to the new version?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Thanks for sharing the issue. We have fixed this issue recently and it will be available in next release.
Govinda Gupta
Votes
Translate
Translate
Report
Report
New Here ,
Jan 08, 2015 Jan 08, 2015
Thank you for your update...
when do you estimate it's release?
Votes
Translate
Translate
Report
Report
Explorer ,
Feb 09, 2015 Feb 09, 2015
It seems to be worse in AIR16 (250)
Now not only doesn't ask, but revokes permission if already given.
https://bugbase.adobe.com/index.cfm?event=bug&id=3920359
Does anyone know when this may be fixed otherwise no apps that use GPS will get to App Store?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Could you please try the options as suggested in the links given below.
Please let us know if the issue persists.
Adobe Air Team
Votes
Translate
Translate
Report
Report
Explorer ,
The apps that have the problem are implemented as per that documentation and work when compiled with AIR15.0 en_US (build 20140701)
When compiled with AIR 16 it behaves exactly as described by Leo Chen in the bug report attached
i.e.
- iOS no longer ask user to grant permission to use location service,
- if you have previously granted your app location service permission, iOS will revoke it silently.
- you may manually switch to iOS's settings, and grant your app permission to access iOS's location service (in iOS's "General > Privacy >Location service - find your app's name - set to Always"), while your app is already in running, HOWEVER, iOS will reset IMMEDIATELY when you switch back to your app, or when you trigger the function that requires to use Geolocation api
Votes
Translate
Translate
Report
Report
Explorer ,
Solution:
wasn't obvious that a change was required from AIR 15 to AIR 16 but is in the Adobe documentation at:
Adobe AIR * iOS Settings
under
Geolocation Support
Paul
Votes
Translate
Translate
Report
Report
Feb 26, 2015 Feb 26, 2015
That's it! Thanks a lot!
Votes
Translate
Translate
Report
Report
Engaged ,
Mar 20, 2015 Mar 20, 2015
LATEST
so i am trying to figure this out with no luck. I am compiling on AIR 17 (beta) and i  have included the following:
<iPhone>
    <Entitlements>
  <![CDATA[ <key>get-task-allow</key>
  <false/>
  <key>beta-reports-active</key>
  <true/> ]]>
  </Entitlements>
        <InfoAdditions><![CDATA[
  <key>UIDeviceFamily</key>
  <array>
  <string>1</string>
  <string>2</string>
  </array>
          <key>NSLocationAlwaysUsageDescription</key>
             <string>Sample description to allow geolocation always</string>
             <key>NSLocationWhenInUseUsageDescription</key>
             <string>Sample description to allow geolocation when application is in foreground</string>
  ]]></InfoAdditions>
        <requestedDisplayResolution>high</requestedDisplayResolution>
    </iPhone>
any ideas?
Votes
Translate
Translate
Report
Report
