1 Reply Latest reply on Dec 4, 2014 8:52 AM by A.T. Romano
    Why can't I get color adjustments to work on all clips?
    ExpressiveGlass
      My video clips have a red tint.  I've clicked on Adjustments in Expert mode in Premier Elements. Under "Color" I clicked on "Auto Color." and it color corrected the clip. This worked on 2 clips, but then wouldn't work on any other clips. I tried other adjustments, such as increasing the Green tint in Color (RGB).  That also worked on a few clips and then stopped. Please help.
        • 1. Re: Why can't I get color adjustments to work on all clips?
          A.T. Romano Level 7
          ExpressiveGlass
          What version of Premiere Elements are you using and on what computer operating system is it running? Since you mention "Expert workspace", I am assuming that you are using either Premiere Elements 11, 12, or 13.
          Two clips worked with Adjust Tab/Color and its Auto Color. But for the others that did not do as well with Auto Color, did you do manual options under Color?
          Same for Color RGB
          Did you try any of the fx Effects/Color Correction, like Split Tone
          ATR
