6 Replies Latest reply on Dec 5, 2014 4:59 AM by John Wilheim
    Set top and bottom inset spacing values in Text Frame Options via jsx script
    John Wilheim
      I am looking for a way to set the top and bottom inset spacing values only to 2 points in Text Frame Options via a .jsx scrpt.
      For years, I have used a script that sets Preferences, such as:
      with(app.storyPreferences){
          opticalMarginAlignment = false;
          opticalMarginSize = 12;                // pts
      I would like to add the code to this same script that would make Top = 0p2 and Bottom 0p2 but leave Left and Right as 0p0.
      Any help would be greatly appreciated.
        • 1. Re: Set top and bottom inset spacing values in Text Frame Options via jsx script
          Sajeev Sridharan Level 4
          Have you checked the below link, this may help you to proceed further
          Increase/Decrease inset spacing
          Vandy
          • 2. Re: Set top and bottom inset spacing values in Text Frame Options via jsx script
            John Wilheim Level 1
            I did see that before I entered my post, but am not sure how to SET the desired values, as opposed to changing them.
            • 3. Re: Set top and bottom inset spacing values in Text Frame Options via jsx script
              Peter Kahrel Adobe Community Professional & MVP
              John,
              The code you have ("with(app.storyPreferences)" and all that) sets things in a story. What you want to add ("Top = 0p2 and Bottom 0p2") I assume are text frame insets, and therefore relate to text frames. Stories, naturally, live in text frames (technically, in textContainers), but their relationship is not clear from your question. Do you want to set the insets of text frames? If yes, you'd better do that in an object style.
              Peter
              • 4. Re: Set top and bottom inset spacing values in Text Frame Options via jsx script
                Hi, Peter.
                I want to do whatever is necessary so that every time a text frame is created, it has 2 points of inset at the top and bottom.
                I do not know how to do object style; I only know what is in the script from which I excerpted the copy of lines, and everything in that script is for Preferences.
                Can you tell me how to do what I want for text frames?
                • 5. Re: Set top and bottom inset spacing values in Text Frame Options via jsx script
                  Here is the full .jsx file that we now use to set preferences.
                  Ideally, this could be modified to include setting any text frame created to have 0p2 inset Top and Bottom, but 0p0 Left and Right:
                  //ApplicationTextDefaults
                  //An InDesign CS2 JavaScript
                  //Sets the application text defaults, which will become the text defaults for all
                  //new documents. Existing documents will remain unchanged.
                  with(app.textDefaults){
                      alignToBaseline = false;        // align to baseline grid
                      try {
                  //        appliedFont = app.fonts.item("Times New Roman");
                          appliedFont = app.fonts.item("Helvetica");
                      catch (e) {}
                      try {
                          fontStyle = "Medium";
                      catch (e) {}
                      autoleading = 100;
                      balanceRaggedLines = false;
                      baselineShift = 0;
                      capitalization = Capitalization.normal;
                      composer = "Adobe Paragraph Composer";
                      desiredGlyphScaling = 100;
                      desiredLetterSpacing = 0;
                      desiredWordSpacing = 100;
                      dropCapCharacters = 0;
                      if (dropCapCharacters != 0) {
                          dropCapLines = 3;
                          //Assumes that the application has a default character style named "myDropCap"
                          //dropCapStyle = app.characterStyles.item("myDropCap");
                      fillColor = app.colors.item("Black");
                      fillTint = 100;
                      firstLineIndent = "0pt";
                  //    firstLineIndent = "14pt";
                      gridAlignFirstLineOnly = false;
                      horizontalScale = 100;
                      hyphenateAfterFirst = 3;
                      hyphenateBeforeLast = 4;
                      hyphenateCapitalizedWords = false;
                      hyphenateLadderLimit = 1;
                      hyphenateWordsLongerThan = 5;
                      hyphenation = true;
                      hyphenationZone = "3p";
                      hyphenWeight = 9;
                      justification = Justification.leftAlign;
                      keepAllLinesTogether = false;
                      keepLinesTogether = true;
                      keepFirstLines = 2;
                      keepLastLines = 2;
                      keepWithNext = 0;
                      kerningMethod = "Optical";
                      kerningValue = 0;
                      leading = 6.3;
                  //    leading = 14;
                      leftIndent = 0;
                      ligatures = true;
                      maximumGlyphScaling = 100;
                      maximumLetterSpacing = 0;
                      maximumWordSpacing = 160;
                      minimumGlyphScaling = 100;
                      minimumLetterSpacing = 0;
                      minimumWordSpacing = 80;
                      noBreak = false;
                      otfContextualAlternate = true;
                      otfDiscretionaryLigature = true;
                      otfFigureStyle = OTFFigureStyle.proportionalOldstyle;
                      otfFraction = true;
                      otfHistorical = true;
                      otfOrdinal = false;
                      otfSlashedZero = true;
                      otfSwash = false;
                      otfTitling = false;
                      overprintFill = false;
                      overprintStroke = false;
                      pointSize = 6.3;
                  //    pointSize = 11;
                      position = Position.normal;
                      rightIndent = 0;
                      ruleAbove = false;
                      if(ruleAbove == true){
                          ruleAboveColor = app.colors.item("Black");
                          ruleAboveGapColor = app.swatches.item("None");
                          ruleAboveGapOverprint = false;
                          ruleAboveGapTint = 100;
                          ruleAboveLeftIndent = 0;
                          ruleAboveLineWeight = .25;
                          ruleAboveOffset = 14;
                          ruleAboveOverprint = false;
                          ruleAboveRightIndent = 0;
                          ruleAboveTint = 100;
                          ruleAboveType = app.strokeStyles.item("Solid");
                          ruleAboveWidth = RuleWidth.columnWidth;
                      ruleBelow = false;
                      if(ruleBelow == true){
                          ruleBelowColor = app.colors.item("Black");
                          ruleBelowGapColor = app.swatches.item("None");
                          ruleBelowGapOverprint = false;
                          ruleBelowGapTint = 100;
                          ruleBelowLeftIndent = 0;
                          ruleBelowLineWeight = .25;
                          ruleBelowOffset = 0;
                          ruleBelowOverprint = false;
                          ruleBelowRightIndent = 0;
                          ruleBelowTint = 100;
                          ruleBelowType = app.strokeStyles.item("Solid");
                          ruleBelowWidth = RuleWidth.columnWidth;
                      singleWordJustification = SingleWordJustification.leftAlign;
                      skew = 0;
                      spaceAfter = 0;
                      spaceBefore = 0;
                      startParagraph = StartParagraph.anywhere;
                      strikeThru = false;
                      if(strikeThru == true){
                          strikeThroughColor = app.colors.item("Black");
                          strikeThroughGapColor = app.swatches.item("None");
                          strikeThroughGapOverprint = false;
                          strikeThroughGapTint = 100;
                          strikeThroughOffset = 3;
                          strikeThroughOverprint = false;
                          strikeThroughTint = 100;
                          strikeThroughType = app.strokeStyles.item("Solid");
                          strikeThroughWeight = .25;
                      strokeColor = app.swatches.item("None");
                      strokeTint = 100;
                      strokeWeight = 0;
                      tracking = 0;
                      underline = false;
                      if(underline == true){
                          underlineColor = app.colors.item("Black");
                          underlineGapColor = app.swatches.item("None");
                          underlineGapOverprint = false;
                          underlineGapTint = 100;
                          underlineOffset = 3;
                          underlineOverprint = false;
                          underlineTint = 100;
                          underlineType = app.strokeStyles.item("Solid");
                          underlineWeight = .25
                      verticalScale = 100;
                  //Units & Increments preference panel
                  //Must do this to make sure our units that we set are in points. The vert and horiz
                  //units that get set default to the current measurement unit. We set it to points
                  //so we can be sure of the value. We'll reset it later to the desired setting.
                  with(app.viewPreferences){
                      horizontalMeasurementUnits = MeasurementUnits.points;    // Ruler Units, horizontal
                      verticalMeasurementUnits = MeasurementUnits.points;        // Ruler Units, vertical
                  //General preference panel
                  with(app.generalPreferences){
                      pageNumbering = PageNumberingOptions.section;    // Page Numbering, View
                      toolTips = ToolTipOptions.normal;                    // Tool Tips
                  // Not supported in CS4
                  //    toolsPalette = ToolsPaletteOptions.doubleColumn;    // Floating Tool Palette
                      completeFontDownloadGlyphLimit = 2000;                // Always Subset Fonts...
                      try {
                          //Wrapped in try/catch in case it is run with CS4 and earlier to avoid the error
                          preventSelectingLockedItems = false;                // Needed for CS5+
                      catch (e) {}
                  //Type preference panel
                  with (app.textEditingPreferences){
                      tripleClickSelectsLine = true;    // Triple Click to Select a Line
                      smartCutAndPaste = true;        // Adjust Spacing Automatically when Cutting and Pasting Words
                      dragAndDropTextInLayout = false;    // Enable in Layout View
                      allowDragAndDropTextInStory = true;    // Enable in Story Editor
                  with(app.textPreferences){
                      typographersQuotes = true;            // Use Typographer's Quotes
                      useOpticalSize = true;                // Automatically Use Correct Optical Size
                      scalingAdjustsText = true;            // Adjust Text Attributes when Scaling
                      useParagraphLeading = false;    // Apply Leading to Entire Paragraphs
                      linkTextFilesWhenImporting = false;    // Create Links when Placing Text and Spreadsheet Files
                  // Missing following (Font Preview Size, Past All Information/Text Only)
                  //Advanced Type preference panel
                      superscriptSize = 58.3;                // Superscript, size
                      superscriptPosition = 33.3;            // Superscript, position
                      subscriptSize = 58.3;                // Subscript, size
                      subscriptPosition = 33.3;            // Subscript, position
                      smallCap = 70;                        // Smallcap
                  with(app.imePreferences){
                      inlineInput = false;                // Use Inline Input for Non-Latin Text
                  //Composition preference panel
                      highlightKeeps = false;                    // Keep Violations
                      highlightHjViolations = false;            // H&J Violations
                      highlightCustomSpacing = false;            // Custom Tracking/Kerning
                      highlightSubstitutedFonts = true;    // Substituted Fonts
                      highlightSubstitutedGlyphs = false;    // Substituted Glyphs
                      justifyTextWraps = false;                // Justify Text Next to an Object
                      abutTextToTextWrap = true;                // Skip by Leading
                      zOrderTextWrap = false;                    // Text Wrap Only Affects Text Beneath
                      rulerOrigin = RulerOrigin.spreadOrigin;                    // Ruler Units, origin
                  //    These are set at the end of the script after all the changes have been made
                  //    horizontalMeasurementUnits = MeasurementUnits.points;    // Ruler Units, horizontal
                  //    verticalMeasurementUnits = MeasurementUnits.inches;        // Ruler Units, vertical
                      pointsPerInch = 72;                    // Point/Pica Size, Points/Inch
                      cursorKeyIncrement = 1;                // Keyboard Increment, Cursor Key
                      baselineShiftKeyIncrement = 2;    // Keyboard Increment, Baseline Shift
                      leadingKeyIncrement = 2;        // Keyboard Increment, Size/Leading
                      kerningKeyIncrement = 20;            // Keyboard Increment, Kerning
                  //Grids preference panel
                  with(app.gridPreferences){
                      baselineColor = UIColors.lightBlue;    // Baseline Grid, Color
                      baselineStart = 48;                        // Baseline Grid, Start
                      baselineDivision = 6;                    // Baseline Grid, Increment Every
                      baselineViewThreshold = 50;                // Baseline Grid, View Threshold
                      baselineGridRelativeOption = BaselineGridRelativeOption.topOfPageOfBaselineGridRelativeOption;    // Baseline Grid, Relative To
                      gridColor = UIColors.lightGray;            // Document Grid, Color
                      horizontalGridlineDivision = 12;    // Document Grid, Horizontal, Gridline Every
                      horizontalGridSubdivision = 12;            // Document Grid, Horizontal, Subdivisions
                      verticalGridlineDivision = 12;            // Document Gird, Vertical, Gridline Every
                      verticalGridSubdivision = 12;            // Document Grid, Vertical, Subdivisions
                      gridsInBack = true;                        // Grids in Back
                      documentGridSnapto = false;                // snap to grid or not
                      documentGridShown = false;                // show document grid
                  //Guides & Pasteboard preference panel
                  with(app.documentPreferences){
                      marginGuideColor = UIColors.violet;                // Color, Margins
                      columnGuideColor = UIColors.magenta;            // Color, Columns
                  with(app.pasteboardPreferences){
                      bleedGuideColor = UIColors.fiesta;                // Color, Bleed
                      slugGuideColor = UIColors.gridBlue;                // Color, Slug
                      previewBackgroundColor = UIColors.lightGray;    // Color, Preview Background
                      minimumSpaceAboveAndBelow = 72;                    // Minimum Vertical Offset
                      guideSnaptoZone = 4;                            // Snap to Zone
                  with(app.guidePreferences){
                      guidesInBack = false;                            // Guides in Back
                  //Dictionary preference panel
                  with(app.dictionaryPreferences){
                      composition = ComposeUsing.both;    // Hyphenatin Exceptions, Compose Using
                      mergeUserDictionary = false;    // Merge User Dictionary into Document
                      recomposeWhenChanged = true;    // Recompose All Stories When Modified
                  // Missing (Lang, Hyph, Spelling, Double Quotes, Single Quotes)
                  //Spelling preference panel
                  with(app.spellPreferences){
                      checkMisspelledWords = true;                    // Find, Misspelled Words
                      checkRepeatedWords = true;                        // Find, Repeated Words
                      checkCapitalizedWords = true;                    // Find, Uncapitalized Words
                      checkCapitalizedSentences = true;                // Find, Uncapitalized Sentences
                      dynamicSpellCheck = true;                        // Enable Dynamic Spelling
                      misspelledWordColor = UIColors.red;                // Color, Misspelled Words
                      repeatedWordColor = UIColors.green;                // Color, Repeated Words
                      uncapitalizedWordColor = UIColors.green;    // Color, Uncapitalized Words
                      uncapitalizedSentenceColor = UIColors.green;    // Color, Uncapitalized Sentences
                  //Autocorrect preference panel
                  with(app.autoCorrectPreferences){
                      autoCorrect = true;                            // Enable Autocorrect
                      autoCorrectCapitalizationErrors = false;    // Autocorrect Capitalization
                  // Missing (Language, Misspelled word pairs)
                  //Display Performance preference panel
                  with(app.displayPerformancePreferences){
                      defaultDisplaySettings = ViewDisplaySettings.typical;    // Preserve Object-Level
                      persistLocalSettings = false;
                  // Missing (antialiasiing, greek below
                  //Story Editor Display preference panel
                  with(app.galleyPreferences){
                      textColor = InCopyUIColors.black;                // Text Color
                      backgroundColor = InCopyUIColors.white;            // Background
                      smoothText = true;                                // Enable Anti-Aliasing
                      antiAliasType = AntiAliasType.grayAntialiasing;    // Type
                      cursorType = CursorTypes.standardCursor;    // Cursor Type
                      blinkCursor = true;                                // Blink
                  // Missing (Font, Size, Line Spacing & Theme)
                  //File Handling preference panel
                      includePreview = true;                        // Always Save Preview Images with Doc
                      previewSize = PreviewSizeOptions.medium;    // Preview Size
                  with(app.clipboardPreferences){
                      preferPDFWhenPasting = false;                // Prefer PDF When Pasting
                      copyPDFToClipboard = true;                    // Copy PDF to Clipboard
                      preservePdfClipboardAtQuit = false;            // Preserve PDF Data at Quit
                  // Missing (Enable Version Cue)
                  //    Optical margin (hanging punctuation, outside margins)
                  //Wrap Up (do at end of script)
                      horizontalMeasurementUnits = MeasurementUnits.picas;    // Ruler Units, horizontal
                  //    These two flags are turned off to avoid the error message about
                  //    missing image links when InDesign opens an ad. This can especially
                  //    be a problem when doing batch processes.
                  with(app.linkingPreferences){
                      checkLinksAtOpen = false;            // checkbox: true/false
                      findMissingLinksAtOpen = false;        // checkbox: true/false
                  • 6. Re: Set top and bottom inset spacing values in Text Frame Options via jsx script
                    Second reply:
                    I have attached the entire .jsx file that we now use to set Preferences.
                    Ideally, this script could be modified so whenever a new text frame is created, the Top and Bottom would have inset of 0p2 but the Left and Right would remain 0p0.
                    I also posted the text of the file in the replies of my original post.
                    • 8. Re: Set top and bottom inset spacing values in Text Frame Options via jsx script
                      app.textFramePreferences.insetSpacing = ['0p2', 0, '0p2', 0];
                      • 9. Re: Set top and bottom inset spacing values in Text Frame Options via jsx script
                        Worked like a charm. Many, many thanks, Peter.
