4 Replies Latest reply on Dec 8, 2014 2:44 AM by camilo umana
    script with replace some of the characters respectively
    hamdifem
      I want to change some of the characters respectively
      where error
      app.findGrepPreferences = app.changeGrepPreferences = null;
      app.changeGrepPreferences.appliedFont = "Symbol";
      app.findGrepPreferences.findWhat =  {"α", "é", "β"};
      app.changeGrepPreferences.changeTo = {"à",  "é", "á"};
      app.changeGrepPreferences.appliedCharacterStyle = myChar1;
      app.activeDocument.changeGrep();
        • 1. Re: script with replace some of the characters respectively
          TᴀW Adobe Community Professional & MVP
          That's not going to work! This isn't .NET where everything is done for you.
          You'll have to take the characters, put them into 2 arrays (no need for
          objects), then loop through the arrays.
          findWhat and changeTo can only take a single search query.
          • 2. Re: script with replace some of the characters respectively
            hamdifem Level 1
            OK I writed a script
            but How can I change the font of "a" character
            main ();
            function main(){
              app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
              if(app.documents.length >= 1){
                             var myDoc=app.activeDocument;
                    editT(myDoc);
                else
              alert("Pleace Open İndesign Doc");
            function editT(myDoc)
                var oldA =["a", "b", "c"]
                var newA =["1", "2", "3"]
                var changee =[["a",0],["b",0],["c",0]]
                for (var i=0; i<oldA.length; i++)
                    app.findTextPreferences = NothingEnum.nothing;
                    app.changeTextPreferences = NothingEnum.nothing;
                    app.findChangeTextOptions.caseSensitive = true;
                    app.findChangeTextOptions.includeFootnotes = false;
                    app.findChangeTextOptions.includeHiddenLayers = false;
                    app.findChangeTextOptions.includeLockedLayersForFind = false;
                    app.findChangeTextOptions.includeLockedStoriesForFind = false;
                    app.findChangeTextOptions.includeMasterPages = false;
                    app.findChangeTextOptions.wholeWord = false;
                    app.findTextPreferences.findWhat = oldA[i]
                    app.changeTextPreferences.changeTo = newA[i];
                    changee[i][1] = app.activeDocument.changeText().length;
                    myDoc.changeText();
            • 3. Re: script with replace some of the characters respectively
              hamdifem Level 1
              O have a question Pleace look forum
              4 Aralık 2014 Perşembe tarihinde,  <forums_noreply@adobe.com> yazdı:
                  script with replace some of the characters respectively  created by
              <https://forums.adobe.com/people/%5BAriel%5D> in *InDesign
              Scripting* - View the full discussion
              <https://forums.adobe.com/message/6985608#6985608>
              • 4. Re: script with replace some of the characters respectively
                Good, that script should work.
                I would recommend to take out of the loop all the findChangeTextOptions
                and everything like that. It is unnecessary to reset them with each loop
                of the loop. Just do it once outside the loop, and in the loop change
                only the findWhat text and changeTo text.
                Regarding your question about the font: well, that is another question
                entirely, so it should be in a new thread.
                • 5. Re: script with replace some of the characters respectively
                  camilo umana Level 1
                  Hamdifem, perhaps a solution is assign a ch. style before the script is run, if copy-text allows it, like in this example.
                  *This seems very useful for making massive substitutions... in find-change operations, although I don't know if find/change scripts by list are in the same line. Also, it works with words but those in both lists have to had the same number of characters. How difficult could be change the lines Ariel recommended? Thanks for this piece that works very well.
