1 Reply Latest reply on Dec 15, 2014 5:27 AM by Avidmcd
    long export times
    Avidmcd
      My company is moving over to Premiere Pro CC from FCP 7. As a relatively newer user of Premiere Pro CC (2014v8.1) I'm trying to figure out how to set my system for faster exports.
      For Example;
      I edited a project in 720p (media was shot in 4K-Sony SxS) import and playback were fine until adding basic Color correction. Then extremely choppy playback until I rendered the timeline.
      Exported the 14:27 timeline to XDcam422HD 60(50mbps) 59.94fps with a data rate 50.11Mbits/s.
      It took  1hour and 18minutes to export!
      For an experiment, I re-edited the exact sequence in Final Cut Pro X 10.10.4 (I have a copy on the same machine) Did the same export.
      Both Files are identical in size, Mbits.sec, etc.  The Export time was 7 Minutes!
      I am sure there has to be a group of settings that I am not aware, that I haven't tweaked or modified to improve the export times.
      Like I said the company is moving us to Premiere ProCC and I want to make sure I can export nearly as quickly. These export times seem unbelievably long and must not have something not set correctly.
      My Sysytem is:
      Mac Pro (Late 2013)
      3.5 GHz 6 core Xeon E5
      Graphics card: AMD Firepro D500 3072
      16GB Ram
      Yosemite 10.10.1
      Premiere Pro CC 2014:
      V8.1
      Mercury Transit is enabled
      13 GB allocated to PPro
      Any help would be appreciated as we will roll this out division wide (about 35 edit stations) within a year.
      Thanks in Advance
      Mark
