1 Reply Latest reply on Dec 5, 2014 9:40 AM by sinious
    Flash CC Crashing on Startup
    flash loadup problem
      Hi all,
      Am getting the below error when trying to load Flash CC.
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: Flash.exe
        Application Version:
        Application Timestamp: 54249160
        Fault Module Name: MSVCR110.dll
        Fault Module Version: 11.0.51106.1
        Fault Module Timestamp: 5098826e
        Exception Code: c00000fd
        Exception Offset: 00000000000536cd
        OS Version: 6.1.7601.
        Locale ID: 2057
        Additional Information 1: b149
        Additional Information 2: b149752970946546bfd06ca1aa3b6c5b
        Additional Information 3: c820
        Additional Information 4: c8209a41a229d33b9d464f350a221197
      Running on Win7 64Bit if that helps
        • 1. Re: Flash CC Crashing on Startup
          sinious Most Valuable Participant
          That fault module explains what's crashing on there which is MS (Microsoft) V (Visual) C (C++) R (Redistributable) from studio 11. It might mean you need to install a newer version, say 2012 or 2013.
          You can find the Microsoft Visual C++ Redistributable by searching here for the Win 7 64bit version:
          On the chance it's Flash having a startup configuration issue you can reset Flash Pro's config by holding CTRL+SHIFT+ALT immediately after starting Flash Pro and allowing it to clear the config. You could try this first before hunting down a newer C++ runtime.
