3 Replies Latest reply on Dec 11, 2014 7:45 AM by sinious
    Help with load and unload swf file.
    rudat
      hello, just now i try, to  load my file using the code snippet 'load and unload' i manage to load the next file succesfully but why my recent file still appear in the background? how do i make it gone?
        • 1. Re: Help with load and unload swf file.
          sinious Most Valuable Participant
          When you load another SWF you're loading it 'inside' the current SWF but it appears that you want to replace the current SWF entirely with the new SWF, is that correct?
          If so you should make what's usually known as a 'stub' or a loader. Make an empty project that merely acts as a loader. It should load your first SWF and when you press a button on that first SWF to load a second SWF, it should signal the 'stub' it's loaded inside to unload the first SWF and then load the second.
          e.g. a stub.swf (just coding out of memory, not error checked, just to give a general idea):
          // make a new loader to do all the loading of SWFs
          var loader:Loader = new Loader();
          // and display
          addChild(loader);
          // a function to load a SWF into the loader (replacing any existing SWF)
          function loadSWF(path:String):void
               // assure path is defined or do nothing
               if (!path) return;
               // load requested SWF
               loader.load(new URLRequest(path));
          // load initial SWF
          loadSWF('/path/to/1.swf');
          For your 1.swf to use the function, you're currently inside the .content property of a Loader so I believe you can just run a command like: Object(this.parent.parent).loadSWF('/path/to/2.swf');
          This example obviously lacks any error checking or transitions but you can add those and season to taste.
          • 2. Re: Help with load and unload swf file.
            rudat Level 1
            ermm. the only problem is that the one with masking effect still remains in the background. no idea how to make it gone...
            • 3. Re: Help with load and unload swf file.
              The Loader class has an unload() method. You can just run that before running a load():
              // unload any existing
              loader.unload();
              // load new file
              Loader class:
              Loader - Adobe ActionScript® 3 (AS3 ) API Reference
