3 Replies Latest reply on Dec 5, 2014 9:55 AM by sinious
    Flash crashes when I insert frames and I loose all my work
    GSellers
      I created a long movie with many layers sliding in and out of the stage...then when I realize I need a frame to stay up for longer I hold [Ctrl] and drag across about 15-20 frames in the layers that need to stay up, then I Right-click and choose Insert Frame...then when I try to Publish/Export/Save the file the error occurs and the file gets destroyed
      Any help would be very appreciated
        • 1. Re: Flash crashes when I insert frames and I loose all my work
          sinious Most Valuable Participant
          This is just asking the basics but can you elaborate on a few things like what OS, what version of Flash, what's on the layers you're extending, etc. The more detail the better the response. For example I've stretched some video frames before and had some various crashing issues. Flash just didn't like the video. I re-encoded a new video, replaced the old video and it was fine. Odd things like that happen time to time.
          • 2. Re: Flash crashes when I insert frames and I loose all my work
            GSellers Level 1
            I'm running Windows 7..version CS6 Pro
            The layers have Text on them that I've converted to Graphics so they can fade in and out when they move on and off the frame
            There is a bar/logo at the bottom of the page that must be on all frames so I've been selecting the layers that have the text and the layers that have the bar/logo so everything stays up for the same amount of time
            The whole purpose for this is so the text can stay up long enough to read it...I created the original file with no problem but when I re-open it to make those "time-based-adjustments" and they go to Save the file this error occurs and it takes my file with it
            Hope this sheds more light on the problem
            • 3. Re: Flash crashes when I insert frames and I loose all my work
              CS6 Pro was pretty rock solid. I actually just noticed a Flash Pro CS6 update today (not sure when it came out), mostly for device packaging but still you should check if you can apply that patch.
              Have you tried saving this file using XFL? Just hit Save-As and hit the drop-down at the bottom and try the XFL format. I prefer this format for a variety of reasons, one of which is it's very easy to store in version management and it externalizes the library assets rather than keeping them all in one "this could blow up and take it all out" single file.
              Do you have a CC subscription?
